Hello, I have the same problem with my Xiaomi x20+, do you have a solution to be able to see the map?
I have a problem with my xiaomi 5S
I used this integrations a lot of time.
Yestarday I see that I canât run vacuum to clean specific room or zone.
When I run vacuum to clean room (or zone) I have message: âfailure to execute vacuum/send_command action. unknown errorâ
This is my card config:
type: vertical-stack
cards:
- type: custom:xiaomi-vacuum-map-card
map_source:
camera: camera.xiaomi_cloud_map_extractor
calibration_source:
camera: true
map_modes:
- template: vacuum_clean_zone_predefined
max_selections: 10
repeats_type: INTERNAL
max_repeats: 5
predefined_selections:
- zones:
- - 25027
- 22127
- 30773
- 26112
- zones:
- - 29987
- 22148
- 32896
- 26091
- zones:
- - 32825
- 22170
- 34767
- 25440
- zones:
- - 29568
- 19521
- 31783
- 22286
- - 27003
- 19142
- 31677
- 20731
- zones:
- - 25027
- 19710
- 27031
- 21971
- zones:
- - 27823
- 20510
- 29070
- 21551
- zones:
- - 31648
- 20698
- 34851
- 22076
- zones:
- - 28180
- 15191
- 30689
- 19197
- zones:
- - 25027
- 15191
- 28082
- 19176
- template: vacuum_goto
entity: vacuum.roborock_s5e_d832_robot_cleaner
vacuum_platform: send_command
map_locked: true
two_finger_pan: true
debug: false
Config:
camera:
- platform: xiaomi_cloud_map_extractor
host: ,xxxxxxxx
token: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
username: xxxxxxxxxxxxxx
password: xxxxxxxxxxxx
draw: [âallâ]
attributes:- calibration_points
colors:
color_charger: [255, 0, 0]
color_map_inside: [32, 115, 185]
color_map_outside: [255, 255, 255]
color_map_wall: [96, 96, 96]
color_map_wall_v2: [93, 109, 126]
color_grey_wall: [255, 255, 255]
color_path: [224, 224, 224]
color_path: [147, 194, 238]
color_goto_path: [0, 255, 0]
color_predicted_path: [255, 255, 0, 0]
color_zones: [0xAD, 0xD8, 0xFF, 0x8F]
color_zones_outline: [0xAD, 0xD8, 0xFF, 0x8F]
color_virtual_walls: [255, 0, 0]
color_no_go_zones: [255, 33, 55, 127]
color_no_go_zones_outline: [255, 0, 0]
color_no_mop_zones: [163, 130, 211, 127]
color_no_mop_zones_outline: [163, 130, 211]
color_charger: [0x66, 0xfe, 0xda, 0x7f]
color_robo: [75, 235, 149]
color_unknown: [0, 0, 0]
color_scan: [0xDF, 0xDF, 0xDF]
room_colors:
1: [255, 204, 204]
2: [51, 205, 153]
3: [117, 136, 128]
4: [52, 152, 219]
5: [205, 97, 85]
6: [243, 156, 18]
7: [88, 214, 141]
8: [245, 176, 65]
9: [252, 212, 81]
10: [72, 201, 176]
11: [84, 153, 199]
12: [133, 193, 233]
13: [245, 176, 65]
14: [82, 190, 128]
15: [72, 201, 176]
16: [165, 105, 18]
# texts:
# - text: "Room 1"
# x: 25
# y: 25
# color: [125, 20, 213]
map_transformation:
# scale: 0.6
trim:
top: 22
bottom: 20
left: 24
right: 24
Use built-in Xiaomi Miio integration instead of Miot Auto
In Xiaomi Miio integration, I also have this. But I donât know what I need to change to make it work especially since it worked and I didnât change anything myself.
Hi Piotr,
Iâve been using your plugin for a while now, and it works like a charmâthank you for that! Today, while checking my logs for another issue, I came across this entry. Should I be concerned about it, especially since it will be deprecated in the next release?
Logger: homeassistant.components.camera
Source: helpers/deprecation.py:222
integration: Camera (documentation, issues)
First occurred: 13:47:58 (2 occurrences)
Last logged: 13:47:58
SUPPORT_ON_OFF was used from xiaomi_cloud_map_extractor, this is a deprecated constant which will be removed in HA Core 2025.1. Use CameraEntityFeature.ON_OFF instead, please report it to the author of the âxiaomi_cloud_map_extractorâ custom integration
Use the vacuum entity from the Xiaomi Miio integration and change vacuum platform to default
Also, this question is more suited for this thread
I plan to fix these before release of 2025.1
Same for me. I am also using the X20+ and no map is shown.
Could support for this device be added?
I changed my Vacuum and wanted to update the intergration. My new Vacuum has an API token that only has numbers in it and not a single letter. I have changed some digits but it looks like this:
30627073384668653366626251234567
I now get this when I try and reload HA:
Configuration warnings
Invalid config for âxiaomi_cloud_map_extractorâ from integration âcameraâ at configuration.yaml, line 398: expected str for dictionary value âtokenâ, got 30627073384668653366626251234567
As soon as I change one digit to a letter like this â3f627073384668653366626251234567â I get the good old: Configuration will not prevent Home Assistant from starting!
Which shows that the Key needs a letter which mine does not have.
Just wrap it in double or single quotes
You sir are a genius! Thank you Piotr!
hi piotr.
first thanks for your great work with the map extractor i have now updated to 2025.1 and it unfortunatelly stoped working. Am i right that the mentioned fix is not release yet or?
It has been released last Friday
DzieĆ dobry.
Mam taki komunikat w konfiguracji. Co zrobiĆem Ćșle?:
Platform error âcameraâ from integration âxiaomi_cloud_map_extractorâ - cannot import name âSUPPORT_ON_OFFâ from âhomeassistant.components.cameraâ (/usr/src/homeassistant/homeassistant/components/camera/init.py)
You have to update to the latest version of Map Extractor.
We use English on the forum, please use it as well.
Hey
Would it be possible to add support for the x20+ robot vacuum?
Matt
i have problems with the token_extractor.exe. The 2-FA-Authorization does not work.
When i use the link and paste the code from the E-mail it seems to work and i get the reply âokâ.
Then i restart the token_extractor.exe, but after Username and password there is only another Link
Thanks Iggi
There are several solutions to this problem here
Thank you!
The first Solution worked for me.
