Nope, every color’s attribute is an integer from range 0-255 (as described in README)
@3_14 can you help me with this error?
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 278, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 471, in async_device_update
await self.hass.async_add_executor_job(self.update) # type: ignore
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/config/custom_components/xiaomi_cloud_map_extractor/camera.py", line 186, in update
self._map_data = self._connector.get_map(map_name, self._colors, self._drawables, self._texts, self._sizes,
File "/config/custom_components/xiaomi_cloud_map_extractor/xiaomi_cloud_connector.py", line 105, in get_map
map_data = MapDataParser.parse(unzipped, colors, drawables, texts, sizes, image_config)
File "/config/custom_components/xiaomi_cloud_map_extractor/map_data_parser.py", line 76, in parse
MapDataParser.draw_elements(colors, drawables, texts, sizes, map_data)
File "/config/custom_components/xiaomi_cloud_map_extractor/map_data_parser.py", line 237, in draw_elements
ImageHandler.draw_texts(map_data.image, texts)
File "/config/custom_components/xiaomi_cloud_map_extractor/image_handler.py", line 171, in draw_texts
ImageHandler.__draw_text__(image, text_config[CONF_TEXT], x, y, text_config[CONF_COLOR],
File "/config/custom_components/xiaomi_cloud_map_extractor/image_handler.py", line 217, in __draw_text__
ImageHandler.__draw_on_new_layer__(image, draw_func)
File "/config/custom_components/xiaomi_cloud_map_extractor/image_handler.py", line 231, in __draw_on_new_layer__
draw_function(draw)
File "/config/custom_components/xiaomi_cloud_map_extractor/image_handler.py", line 213, in draw_func
font = ImageFont.truetype(font_file, font_size)
File "/usr/local/lib/python3.8/site-packages/PIL/ImageFont.py", line 655, in truetype
return freetype(font)
File "/usr/local/lib/python3.8/site-packages/PIL/ImageFont.py", line 652, in freetype
return FreeTypeFont(font, size, index, encoding, layout_engine)
File "/usr/local/lib/python3.8/site-packages/PIL/ImageFont.py", line 169, in __init__
if core.HAVE_RAQM:
File "/usr/local/lib/python3.8/site-packages/PIL/ImageFont.py", line 43, in __getattr__
raise ImportError("The _imagingft C module is not installed")
ImportError: The _imagingft C module is not installed
Hi, sometimes I get this error:
Logger: homeassistant.helpers.entity
Source: custom_components/xiaomi_cloud_map_extractor/camera.py:190
First occurred: 9:53:56 (2 occurrences)
Last logged: 9:54:02
Update for camera.xiaomi_cloud_map_extractor fails
File "/usr/local/lib/python3.8/site-packages/PIL/ImageFile.py", line 506, in _save
fh = fp.fileno()
AttributeError: '_idat' object has no attribute 'fileno'
File "/config/custom_components/xiaomi_cloud_map_extractor/camera.py", line 190, in update
self._map_data.image.data.save(img_byte_arr, format='PNG')
File "/usr/local/lib/python3.8/site-packages/PIL/Image.py", line 2158, in save
save_handler(self, fp, filename)
File "/usr/local/lib/python3.8/site-packages/PIL/PngImagePlugin.py", line 1284, in _save
ImageFile._save(im, _idat(fp, chunk), [("zip", (0, 0) + im.size, 0, rawmode)])
File "/usr/local/lib/python3.8/site-packages/PIL/ImageFile.py", line 514, in _save
e.setimage(im.im, b)
SystemError: tile cannot extend outside image
What vacuum do you have? Do you have trimming configured?
Xiaomi Mi Robot Vacuum 1st gen. No trim, colours or staff like that
Do you know when does this happen?
Hard to say. I have auto_update set to false and automation that updates entity manually while status is cleaning. I started cleaning and then paused and noticed that my image suddenly disappeared so I checked the logs and found this.
It’s possible that it happens when map data has not been yet provided from a vacuum (because 1st gen always redraws map). I will try to handle this case
I’ve got this error. Any idea?
Source: custom_components/xiaomi_cloud_map_extractor/image_handler.py:213
First occurred: October 15, 2020, 9:42:10 PM (8331 occurrences)
Last logged: 8:56:10 PM
Update for camera.roborock fails
draw_function(draw)
if core.HAVE_RAQM:
Cool, seems my vacuum is supported (roborock s5 max). Does this support multi floor mapping?
When you will switch floor on a vacuum (in Xiaomi app) a camera view will be updated, but calibration of a map card won’t (but soon it should be able to adjust itself).
Right now you can’t change a floor in my component. I will try to implement it, but right now it’s not a priorityj
Mi robot v1.
Do you have any idea how restore backup map after cleaning?
Via ssh I try:
sudo su
chmod 777 /mnt/data/rockrobo
rm /mnt/data/rockrobo/last_map
cp /mnt/data/rockrobo/backup/last_map /mnt/data/rockrobo
reboot
Works great, but I need to do this automatically after cleaning is complete fron HA.
You can probably save these instructions as a script and call it from automation using shell command.
But that triggers the display in HA. I need to run / send it to another device. Or am I wrong?
You can use ssh in a script to execute commands on a vacuum
I have the same model, the card cannot be received, error:
Logger: custom_components.xiaomi_cloud_map_extractor.camera
Source: custom_components/xiaomi_cloud_map_extractor/camera.py:182
Integration: xiaomi_cloud_map_extractor (documentation)
First occurred: 17:01:05 (65 occurrences)
Last logged: 17:23:08
Got exception while fetching the state: No response from the device
Were you able to solve this problem?
STYTJ02YM is not supported and it doesn’t seem to be supported soon.
It’s a pity ( is it because of the MiHome, vacuum cleaner or integration? With this integration, the vacuum cleaner is visible in the HA. Maybe need a telnet port?
