My Xiaomi setup always worked fine in unraid. I’ve had an update for the docker so I ran it, I launch the web ui and says “xiaomi” component is invalid. I check the xiaomi page and see they’ve change “xiaomi” to “xiaomi_aqara”. So I change the configuration file but whatever I do, I can’t get it to find the gateway anymore. I didn’t change anything in the configuration file, only the update broke it. Anyone any ideas?
2017-10-07 14:19:57 WARNING (MainThread) [homeassistant.setup] Setup of xiaomi_aqara is taking over 10 seconds.
2017-10-07 14:20:37 ERROR (SyncWorker_4) [homeassistant.components.xiaomi_aqara] No gateway discovered
2017-10-07 14:20:37 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi_aqara: Component failed to initialize.
Found the fix, had it running in docker with bridge mode on and only port 8123. But I think Xiaomi uses a port to connect to the gateway, when I turned the network type to host it discovered the gateway immediately.
@snds Can I ask exactly how you got this to work, I had HomeAssistant running a number of weeks ago for very first time. I had “xiaomi” added and could see my Xiaomi accessories. Now I have just powered up by HomeAssistant again in a number of weeks, I have changed the component to “xiaomi_aqara” but unfortunately I’m getting the exact same error as you?
