I use the deconz addon&integration and I have a Xiaomi Cube.
Since version 2021.2 there is the feature: “The deCONZ integration added support for logging basic event in the logbook.” but now I have a lot of MyCube fired event '7000'.
messages in my log.
Is there a way to exclude these? As the cube does not have an entity id I don’t know how to exclude it.
Thanks!
Does no one have an idea how to solve this?
Same here.
I’m using IKEA Tradfri Remote Controller (5 switches) and On/Off Dim Buttons.
As with the Cube, they do not appear as Switch - Entities (only the batterylevel as a sensor entity)
After pressing a button ( & deconz_event is fired) following apperas in logbook:
→ tradfri_RC1 ‘Short press’ event for ‘Dim up’ was fired.
Seems that deConz Integration does this, because how could HA know that this button press is a ‘short press’ event?
I tried to exclude in recorder.yaml and logbook.yaml like this:
exclude:
domains:
- deconz_event
- event
No success. I do not know if ‘deconz_event’ can be seen as a ‘domain’.
Since there are no entities, it is not possible to exclude them.
The only configuration in deConz Integration are these hidden/not used options:
dbg_info
dbg_aps
dbg_otau
dbg_zcl
dbg_zdp
which are set to 0 (zero)
Couldn’t find any documentation so far, which levels can be used for what reason.
May be some others Users of Xiaomi or Tradfri Devices has an idea and can help?
HA: core-2021.4.6
deConz: 6.8.0
