I have problems with integrating a Xiaomi door and smoke sensors in HA. In the configuration.yaml the following lines are added:
xiaomi_aqara:
discovery_retry: 10
interface: '192.168.13.51'
gateways:
- mac: 7811DCB7D5aa
key: 2bv7a2q8rjrjkpaa
host: 192.168.249.104
After restarting the gateway and door and smoke sensors are displayed in the GUI. When i close a door the status is changed once. After that no status changes are updated anymore. In the log the following information is found:
Log
2018-06-01 21:33:09 DEBUG (SyncWorker_4) [homeassistant.components.binary_sensor.xiaomi_aqara] Updating xiaomi sensor by polling
2018-06-01 21:33:09 DEBUG (SyncWorker_4) [xiaomi_gateway] _send_cmd >> b’{ “cmd”:“read”,“sid”:“158d0001f26c40”}’
2018-06-01 21:33:09 DEBUG (SyncWorker_4) [xiaomi_gateway] _send_cmd resp << {‘cmd’: ‘read_ack’, ‘model’: ‘magnet’, ‘sid’: ‘158d0001f26c40’, ‘short_id’: 22658, ‘data’: ‘{“voltage”:3035,“status”:“close”}’}
2018-06-01 21:33:09 DEBUG (SyncWorker_4) [xiaomi_gateway] read_ack << {‘cmd’: ‘read_ack’, ‘model’: ‘magnet’, ‘sid’: ‘158d0001f26c40’, ‘short_id’: 22658, ‘data’: ‘{“voltage”:3035,“status”:“close”}’}
2018-06-01 21:33:09 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> : {‘voltage’: 3035, ‘status’: ‘close’}
2018-06-01 21:33:09 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=binary_sensor.door_window_sensor_158d0001f26c40, old_state=<state binary_sensor.door_window_sensor_158d0001f26c40=on; Open since=0, battery_level=47.0, friendly_name=Door Window Sensor_158d0001f26c40, device_class=opening @ 2018-06-01T21:32:08.327587+02:00>, new_state=<state binary_sensor.door_window_sensor_158d0001f26c40=off; Open since=0, battery_level=47.0, friendly_name=Door Window Sensor_158d0001f26c40, device_class=opening @ 2018-06-01T21:33:09.353487+02:00>>
2018-06-01 21:33:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 140336462626376: Sending {‘id’: 2, ‘type’: ‘event’, ‘event’: {‘event_type’: ‘state_changed’, ‘data’: {‘entity_id’: ‘binary_sensor.door_window_sensor_158d0001f26c40’, ‘old_state’: <state binary_sensor.door_window_sensor_158d0001f26c40=on; Open since=0, battery_level=47.0, friendly_name=Door Window Sensor_158d0001f26c40, device_class=opening @ 2018-06-01T21:32:08.327587+02:00>, ‘new_state’: <state binary_sensor.door_window_sensor_158d0001f26c40=off; Open since=0, battery_level=47.0, friendly_name=Door Window Sensor_158d0001f26c40, device_class=opening @ 2018-06-01T21:33:09.353487+02:00>}, ‘origin’: ‘LOCAL’, ‘time_fired’: datetime.datetime(2018, 6, 1, 19, 33, 9, 353503, tzinfo=)}}
2018-06-01 21:33:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 140336211365448: Sending {‘id’: 2, ‘type’: ‘event’, ‘event’: {‘event_type’: ‘state_changed’, ‘data’: {‘entity_id’: ‘binary_sensor.door_window_sensor_158d0001f26c40’, ‘old_state’: <state binary_sensor.door_window_sensor_158d0001f26c40=on; Open since=0, battery_level=47.0, friendly_name=Door Window Sensor_158d0001f26c40, device_class=opening @ 2018-06-01T21:32:08.327587+02:00>, ‘new_state’: <state binary_sensor.door_window_sensor_158d0001f26c40=off; Open since=0, battery_level=47.0, friendly_name=Door Window Sensor_158d0001f26c40, device_class=opening @ 2018-06-01T21:33:09.353487+02:00>}, ‘origin’: ‘LOCAL’, ‘time_fired’: datetime.datetime(2018, 6, 1, 19, 33, 9, 353503, tzinfo=)}}
So the problem is that is sees the sensors and when a status changes it only works once. After that it stops. No status changes are reported anymore.
What i already tried:
- For HA i tried the Hassio image on a PI and Ubuntu with docker configured as Virtual Machine in VMware with the same results.
- I use the latest firmwares with the Xiaomi sensors
- Generate new keys with IOS and Android
- I’m running the latest build of Home Assistant
- I reset my Ubiquiti EdgeRouter Lite to factory defaults
Anyone has suggestions how to solve this problem?
