Since very recently, my Xiaomi Flora Mi report data after a Home Assistant reboot, and then very quickly lose connection. I’ve tried disabling other devices on the network to make sure it’s not some sudden interference; no change.
I’m running Home Assistant on a Raspberry Pi 4.
Could a recent update have been the reason? Anyone else with the problem?
Found the culprit. I had installed the ble_monitor integration which apparently interferes with the built-in Xiaomi BLE integration. I’ve reported a bug at ble_monitor, let see what gives.
Do you still need ble_monitor now that HA have its own bluetooth integration? I have remove the custom integration ble_monitor all my xiaomi ble temperture/humidity sensor works fine
