I’m very new to HASS and MQTT, and I hope someone can help me with my problem.
I want to add a Xiaomi Flora sensor to HASS and want to read the plant data with my Nuc7 over BTL and PlantGateway (https://github.com/ChristianKuehnel/plantgateway).
My Hass appliance is a virtual machine running on my Qnap, so I have to send the data from my NUC with MQTT to it, MQTT Server is Mosquitto on the appliance.
I discovered the MAC from the sensor and PlantGateway looks good so far, that’s the result if I run it:
Thu, 08 Aug 2019 13:10:07 INFO PlantGateway version 0.6.2
Thu, 08 Aug 2019 13:10:07 INFO loaded config file from /home/user1/.plantgw.yaml
Thu, 08 Aug 2019 13:10:07 INFO Getting data from sensor feige
Thu, 08 Aug 2019 13:10:07 INFO sent sensor config to topic homeassistant/sensor/plant_C47C8D6B2597_battery/config
Thu, 08 Aug 2019 13:10:07 INFO sent sensor config to topic homeassistant/sensor/plant_C47C8D6B2597_temperature/config
Thu, 08 Aug 2019 13:10:07 INFO sent sensor config to topic homeassistant/sensor/plant_C47C8D6B2597_brightness/config
Thu, 08 Aug 2019 13:10:07 INFO sent sensor config to topic homeassistant/sensor/plant_C47C8D6B2597_moisture/config
Thu, 08 Aug 2019 13:10:07 INFO sent sensor config to topic homeassistant/sensor/plant_C47C8D6B2597_conductivity/config
Thu, 08 Aug 2019 13:10:07 INFO sent sensor config to topic homeassistant/sensor/plant_C47C8D6B2597_timestamp/config
Thu, 08 Aug 2019 13:10:07 INFO MQTT connection returned result: Connection Accepted.
Thu, 08 Aug 2019 13:10:10 INFO sent data to topic home/plants/feige/
Thu, 08 Aug 2019 13:10:10 INFO Disconnected MQTT connection
For now I have discovery enabled in MQTT and the PlantGateway.
HASS shows my plant “Feige” but it’s empty:
Can somebody please have a look at my config and tell me what’s wrong? I’ve searched a lot and already read https://www.home-assistant.io/components/miflora/ and https://www.home-assistant.io/components/plant/ … but I don’t get it.
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
mqtt:
broker: localhost
client_id: PlantGateway
discovery: true
discovery_prefix: homeassistant
username: mqtt_user
password: mqtt_pass
plant:
Feige:
sensors:
moisture: sensor.feige_moisture
temperature: sensor.feige_temperature
brightness: sensor.feige_brightness
battery: sensor.feige_battery
conductivity: sensor.feige_conductivity
min_moisture: 15
max_moisture: 60
min_battery: 15
min_conductivity: 350
max_conductivity: 800
min_temperature: 5
max_temperature: 35
min_brightness: 3000
max_brightness: 70000
- platform: mqtt
state_topic: "home/plants/feige/"
value_template: '{{ value_json.moisture | int }}'
unit_of_measurement: '%'
force_update: true
- platform: mqtt
value_template: '{{ value_json.brightness | int }}'
unit_of_measurement: 'Lux'
force_update: true
- platform: mqtt
value_template: '{{ value_json.temperature | float }}'
unit_of_measurement: '°C'
force_update: true
- platform: mqtt
value_template: '{{ value_json.battery | int }}'
force_update: true
- platform: mqtt
value_template: '{{ value_json.conductivity | int }}'
unit_of_measurement: 'µS/cm'
force_update: true
That’s my PlantGateway Config:
mqtt:
server: hassio.home
prefix: home/plants
port: 1883
user: mqtt_user
password: mqtt_pass
sensors:
- mac: C4:7C:8D:6B:25:97
alias: feige
Thanks in advance
