Xiaomi Gateway 3 - Aqara Magic Cube (9 Actions)
Aqara Magic Cube with Xiaomi Gateway 3
Basic blueprint for executing supported actions with the Aqara Magic Cube and Xiaomi Gateway 3 using original firmware.
Supports the following actions:
  • Wake
  • Double Tap
  • Move
  • Drop
  • Shake
  • Flip 90º
  • Flip 180º
  • Rotate Right
  • Rotate Left
Requirements:
Changelog:
  • 2022.01.25 - First Release
  • 2022.02.14 - Fix for v2.0.0 compatibility (some actions were renamed).
Soon - More Cube actions based on side
Blueprint Code
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Or import this Blueprint by using the Gist URL:
Xiaomi Gateway 3 - Aqara Magic Cube · GitHub
Older version
If you're on V1.6.5 or lower use the blueprint below:
Other blueprints for Xiaomi Gateway 3
(not by me)
[Xiaomi Gateway 3] Xiaomi Wireless Remote Switch (WXKG01LM) - Working DEC 2021
Sonoff Button SNZB-01 with Xiaomi Gateway 3
Thanks for the blueprint, works well. Xiaomi Gateway 3 Custom Integration it’s released to v2.0 with more action option for the cube.
Could you update the blueprint?
Hello! This one still functions normally, but I’m already working on the new actions and will update or release a new blueprint soon.
No , all movement don’t works. Move, now it’s Slide.
Good news :slight_smile:
Hey, I had some busy days, and you were right! A lot of stuff had stopped working. My most used (rotate and flip) were fine, but now I also fixed: wake up, slide, tapping, shaking and falling.
As for all the side validations, soon.
thanks for update, but are missing actions. Each face has a number
ex:
Action flip90
From side 1
To side 0
It would not be possible to integrate the face number for more actions ?
Yes, I’m working on adding it, but it’s a lot of actions and complexity. I also want to be able to rotate based on side to change TV volume or lights brightness.
I know it’s hard to implement. But if you work on it that’s cool. Already 9 actions is good :slight_smile:
I added slide and double tap on all sides, and now it’s been 19 actions. I’m going to add the flip90° and flip180° but it’s a lot of work. Wake Up, rotate, free fall and shake haven’t the infos for sides, impossible to exploit.
blueprint:
  name: Aqara Magic Cube with Xiaomi Gateway 3
  description: |
    ## Aqara Magic Cube with Xiaomi Gateway 3
    Basic blueprint for executing supported actions with the Aqara Magic Cube and Xiaomi Gateway 3 using default firmware.
    - Wake
    - Double Tap
    - Move
    - Drop
    - Shake
    - Flip 90˚
    - Flip 180˚
    - Rotate Right
    - Rotate Left
    ### Requirements:
    - [Xiaomi Gateway 3 Integration][1] v2.0.0+
    - Official Firmware for the Gateway
    - Paired Aqara Magic Cube
    [1]: https://github.com/AlexxIT/XiaomiGateway3
  domain: automation
  input:
    trigger_entity:
      description: Choose Aqara Cube Action entity
      selector:
        entity:
          domain: sensor
          integration: xiaomi_gateway3
    alert:
      description: Actions to run when cube wakes up (idle and you tap it)
      default: []
      selector:
        action: {}
    tap_twice_side0:
      name: Double Tap Side 0 Aqara Logo
      description: Actions to run when cube is tapped twice (hold it with your hands and tap it twice the table)
      default: []
      selector:
        action: {}
    tap_twice_side1:
      name: Double Tap Side 1
      default: []
      selector:
        action: {}
    tap_twice_side2:
      name: Double Tap Side 2
      default: []
      selector:
        action: {}
    tap_twice_side3:
      name: Double Tap Side 3
      default: []
      selector:
        action: {}
    tap_twice_side4:
      name: Double Tap Side 4
      default: []
      selector:
        action: {}
    tap_twice_side5:
      name: Double Tap Side 5
      default: []
      selector:
        action: {}
    move_side0:
      name: Move Side 0 Aqara Logo
      description: Actions to run when cube is moved (slide in any direction)
      default: []
      selector:
        action: {}
    move_side1:
      name: Move Side 1
      default: []
      selector:
        action: {}
    move_side2:
      name: Move Side 2
      default: []
      selector:
        action: {}
    move_side3:
      name: Move Side 3
      default: []
      selector:
        action: {}
    move_side4:
      name: Move Side 4
      default: []
      selector:
        action: {}
    move_side5:
      name: Move Side 5
      default: []
      selector:
        action: {}
    free_fall:
      description: Actions to run when cube is dropped (throw in the air and catch)
      default: []
      selector:
        action: {}
    shake_air:
      description: Actions to run when cube is shaked (hold in your hands and shake)
      default: []
      selector:
        action: {}
    flip90:
      description: Actions to run when cube is flipped 90 degrees (flipped to any side)
      default: []
      selector:
        action: {}
    flip180:
      description: Actions to run when cube is flipped 180 degrees (flipped to the previous bottom side)
      default: []
      selector:
        action: {}
    rotate_right:
      description: Actions to run when cube is rotated right (turned clockwise)
      default: []
      selector:
        action: {}
    rotate_left:
      description: Actions to run when cube is rotated left (turned counter clockwise)
      default: []
      selector:
        action: {}
variables:
  action: '{{ trigger.to_state.state }}'
  - platform: state
    entity_id: !input trigger_entity
condition: []
  - choose:
      - conditions:
          - "{{ action == 'wakeup' }}"
        sequence: !input "alert"
      - conditions:
          - "{{ action == 'tap' }}"
          - condition: numeric_state
            entity_id: !input 'trigger_entity'
            attribute: side
            below: '1'
        sequence: !input "tap_twice_side0"
      - conditions:
            attribute: side
            above: '0'
            below: '2'
        sequence: !input "tap_twice_side1"
      - conditions:
            attribute: side
            above: '1'
            below: '3'
        sequence: !input "tap_twice_side2"
      - conditions:
            attribute: side
            above: '2'
            below: '4'
        sequence: !input "tap_twice_side3"
      - conditions:
            attribute: side
            above: '3'
            below: '5'
        sequence: !input "tap_twice_side4"
      - conditions:
            attribute: side
            above: '4'
            below: '6'
        sequence: !input "tap_twice_side5"
      - conditions:
          - "{{ action == 'slide' }}"
            attribute: side
            below: '1'
        sequence: !input "move_side0"
      - conditions:
            attribute: side
            above: '0'
            below: '2'
        sequence: !input "move_side1"
      - conditions:
            attribute: side
            above: '1'
            below: '3'
        sequence: !input "move_side2"
      - conditions:
            attribute: side
            above: '2'
            below: '4'
        sequence: !input "move_side3"
      - conditions:
            attribute: side
            above: '3'
            below: '5'
        sequence: !input "move_side4"
      - conditions:
            attribute: side
            above: '4'
            below: '6'
        sequence: !input "move_side5"
      - conditions:
          - "{{ action == 'fall' }}"
        sequence: !input "free_fall"
      - conditions:
          - "{{ action == 'shake' }}"
        sequence: !input "shake_air"
      - conditions:
          - "{{ action == 'flip90' }}"
        sequence: !input "flip90"
      - conditions:
          - "{{ action == 'flip180' }}"
        sequence: !input "flip180"
      - conditions:
          - "{{ action == 'rotate' }}"
            attribute: angle
            above: '0'
        sequence: !input "rotate_right"
      - conditions:
            attribute: angle
            below: '0'
        sequence: !input "rotate_left"
    default: []
mode: queued
max_exceeded: silent
Hello friend, nice work. My daughter arrived this week and I didn’t get a minute to sit at my computer, but we can keep track of sides using an helper outside the automation, such as a input number.
If you have a solution, I would wait for your work because I don’t see how to do it.
Hello, I would like to use this blueprints, but I have the first generation of Xiaomi Gateway with Mi Cube.
Do you think it’s possible to adapt this blueprint with this gateway ?
The integration used is “xiaomi_aqara”, the cube is a “binary_sensor” entity with attributes :
last_action: shake_air, rotate etc…
voltage: xxx
battery_level: xx
friendly_name: xxxx
Thanks in advance for your reply and tell me if it’s possible to adapt this blueprint by editig yaml :slight_smile:
