Hi!
I try integrate Xiaomi gateway 3 (ZNDMWG02LM on original firmware.1.4.6_0043), gateway was istalled:
but next when I was added integrations something going wrong:
" Wrong open telnet command", why?
What is the correct command?
Hi!
I found correct command (Xiaomi Gateway 3: Перепрошивка и добавление в HA - Simple HA):
{"method":"set_ip_info","params":{"ssid":"\"\"","pswd":"123123 ; passwd -d admin ; echo enable > /sys/class/tty/tty/enable; telnetd"}}
Now all works fine.
thanks!!! work perfect!
I have this issue and I don’t understand where is supposed to add that, and If I need to change that code? any advise please?
