Hey!
i connected the Xiaomi gateway and i want to set this automation:
When the gateway activate alaram (based on the logic i set in the MiHome app)
send a HTTP call to Twilio.
Is it possible?
Yirmi
Hey!
Is it possible?
Yirmi
take a look at Arm/disarm Xiaomi Gateway alarm
Thanks! I’ll try it.
Hi All,
I think my problem is linked to the same subject.
I try to set up an automation to activate siren and light when my one of the sensors are opened and the alarm_control_panel is arm_home or arm_away.
when i run the automation, it works perfectly, However, when i arm the alarm_control_panel and i opened the door sensor, the automation is not run!!
I didn’t see the issue in this code
Any ideas? Thanks
this is the Yaml code :
alias: Trigger Alarm Home
description: ''
- type: opened
platform: device
device_id: d7a57f8c067970235d9db7e0670bca49
entity_id: binary_sensor.door_window_sensor_158d00040221a9
domain: binary_sensor
for:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
condition:
- condition: state
entity_id: alarm_control_panel.home_alarm
state: arm_home
- type: turn_on
device_id: a8b6708062ba2a1015dc8a183a9dfd9b
entity_id: light.mi_hub_light
domain: light
- service: notify.mobile_app_sm_g780f
message: Alarme déclenchée!! intrus!
- service: script.script_alarm
mode: single
Are you using the out of the box MIIO integration?
Xiaomi Miio - Home Assistant suggests the state should be armed_away
- there doesn’t seem to be a arm_home
