Xiaomi gateway connection problems
HI All,
As i am using Home Assistant now for my home automation i would like to get rid of all the errors it gives.
The most annoying one is the problem with my Xiaomi gateway. I think it has some connection problems.
Sometimes when just restarting Home Assistant the problem is solved.
When that does not help i restart the modem and most of the time the problem is solved.
Restarting the gateway itself does not solve the problem.
As this is very annoying i would like to solve the problem but i do not know where to start.
In the log i find:
No data in response from hub None
7:11 components/xiaomi_aqara/switch.py (ERROR) - message first occured at 8 september 2019 22:23 and shows up 1589 times
Cannot connect to Gateway
Update of switch.plug_158d00015d3faa is taking over 10 seconds
7:11 main.py (WARNING) - message first occured at 8 september 2019 22:23 and shows up 795 times
When opening the full log i see a long list with different timestamps and the following notification:
2019-09-07 05:28:22 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.plug_158d000156f903 is taking over 10 seconds
2019-09-07 05:28:22 ERROR (SyncWorker_17) [xiaomi_gateway] Cannot connect to Gateway
2019-09-07 05:28:22 ERROR (SyncWorker_17) [xiaomi_gateway] No data in response from hub None
What could i do to solve this problem?
Geert
