… uhhh well correct it and it should work fine. Don’t put the automation underneath the automation: !include automations.yaml but inside the automation.yaml and remove the first trigger:
I thought I tried everything. Thank you, this now shows up in Hassio.
My thinking was that ‘switch_158d000xxxxxc2’ would be linked to the top button on the Gateway. This doesn’t seem to be the case. By double clicking the default ‘arming’ turns on.
Is it possible to reprogram the button to turn on a light?
did you get it work? if not there is easy way , just enter to your HA config website at IP:PORT/dev-state
and see if the HomeAssitant have Recognized the switch , its need to be something like : binary_sensor.switch_XXXXXXX
or binary_sensor.wall_switch_XXXX_XXXXX
Depending on the type of button
