I can’t seem to get my Xiaomi gateway to fully work. I am getting readings from the Temperature/Humidity/Pressure sensors just fine, as well as the Luminance sensors built into my gen 2 Motion detectors, but the motion detectors, as well as the flood sensors, are not showing up in Home Assistant like they used to.
I’m getting this error on startup:
Error while setting up platform xiaomi_aqara
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 129, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/config/custom_components/binary_sensor/xiaomi_aqara.py", line 36, in setup_platform
devices.append(XiaomiWaterLeakSensor(device, gateway))
File "/config/custom_components/binary_sensor/xiaomi_aqara.py", line 223, in __init__
xiaomi_hub, 'status', 'moisture')
File "/config/custom_components/binary_sensor/xiaomi_aqara.py", line 68, in __init__
XiaomiDevice.__init__(self, device, name, xiaomi_hub)
File "/usr/lib/python3.6/site-packages/homeassistant/components/xiaomi_aqara.py", line 219, in __init__
self.parse_data(device['data'], device['raw_data'])
TypeError: parse_data() takes 2 positional arguments but 3 were given
