Xiaomi gateway events not triggered
Hi all,
Running fresh installation of home assistant 0.93.0 with a miniconda environment. I have the following automation:
  • id: ‘1558015993267’
    alias: toggle plug xiaomi
    • event_data:
      click_type: single
      entity_id: binary_sensor.switch_158d0002132b00
      event_type: click
      platform: event
      condition: []
    • data:
      entity_id: switch.plug_158d0001bbfb48
      service: switch.toggle
When I manually fire the event, it works fine:
2019-05-16 21:55:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event click[R]: click_type=single, entity_id=binary_sensor.switch_158d0002132b00>
2019-05-16 21:55:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event automation_triggered[L]: name=toggle plug xiaomi, entity_id=automation.toggle_plug_xiaomi>
2019-05-16 21:55:55 INFO (MainThread) [homeassistant.components.automation] Executing toggle plug xiaomi
2019-05-16 21:55:55 INFO (MainThread) [homeassistant.helpers.script] Script toggle plug xiaomi: Running script
2019-05-16 21:55:55 INFO (MainThread) [homeassistant.helpers.script] Script toggle plug xiaomi: Executing step call service
but when I press the corresponding button, the event is recognized but no automation is triggered:
2019-05-16 21:58:39 DEBUG (Thread-2) [xiaomi_gateway] MCAST (report) << {‘cmd’: ‘report’, ‘model’: ‘sensor_switch.aq2’, ‘sid’: ‘158d0002132b00’, ‘short_id’: 2370, ‘data’: ‘{“status”:“click”}’}
2019-05-16 21:58:39 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> : {‘status’: ‘click’}
2019-05-16 21:58:39 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event xiaomi_aqara.click[L]: entity_id=binary_sensor.switch_158d0002132b00, click_type=single>
and that’s all, the automation is not triggered.
I had this exact problem in another hass installation since I upgraded to 0.92. In fact, I had to downgrade to 0.80.0 to make it work. This is the reason I’m trying a separate fresh installation.
Any ideas?
Should be
event_type: xiaomi_aqara.click
There was a breaking change for this some releases ago.
Thanks for the reply. I’ve not tried yet (I will try when come back home), but yes, in fact the log shows “xiaomi_aqara.click”, and in older version shows as “click”. But I can’t still understand why the automation triggers when I fire the event manually.
Anyway, thanks a lot for your suggestion. I will try this afternoon.
Regards.
Thanks @tjntomas, it did the trick!
If you’re manually firing an event called click and your automation is listening for an event_type of click, it would still work. But since the component itself changed, that’s why it no longer worked until you changed your automation.
absolutely right @apop
