Xiaomi Gateway failed to initialized after upgrade the HA to 0.53.1
i upgraded the HA from 0.52 to 0.53.1, then i find the Xiaomi Gateway disappear. i checked the start up log as bellow:
9月 19 04:28:34 hassbian hass[28053]: 2017-09-19 04:28:34 ERROR (MainThread) [homeassistant.setup] Not initializing xiaomi because could not install dependency https://github.com/Danielhiversen/PyXiaomiGateway/archive/0.3.2.zip#PyXiaomiGateway==0.3.2
9月 19 04:28:34 hassbian hass[28053]: 2017-09-19 04:28:34 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi: Could not install all requirements.
9月 19 04:28:34 hassbian hass[28053]: 2017-09-19 04:28:34 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=title=Invalid config, message=The following components and platforms could not be set up:
9月 19 04:28:34 hassbian hass[28053]: * xiaomi
Any ideas? everything else works fine in HA 0.53.1 like the trackers, weather, group.
[email protected] is upgraded as well.
https://github.com/home-assistant/home-assistant/issues/9495
0.53.1 is the latest one. right?
Yes. Please open and read your issue. :wink:
seems i got your reply in github. :slight_smile:
