great, thanks! that was the thing i was looking for for a couple of days
it now shows the gateway on the start page, i see the status and can click to see the brightness level and the color, but i can’t change any of these. do you have a hint regarding this?
2017-10-04 20:48:58 WARNING (MainThread) [homeassistant.components.xiaomi_aqara] Static address (10.0.0.2:9898) of the gateway provided. Discovery of this host will be skipped.
2017-10-04 20:49:09 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-10-04 20:49:09 WARNING (MainThread) [homeassistant.setup] Setup of weather is taking over 10 seconds.
2017-10-04 20:49:13 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
2017-10-04 20:49:35 WARNING (SyncWorker_7) [netdisco.ssdp] Error fetching description at 10.0.0.11
2017-10-04 20:49:41 WARNING (SyncWorker_7) [netdisco.ssdp] Error fetching description at http://192.168.1.250:49152/description.xml
2017-10-04 20:49:50 ERROR (SyncWorker_3) [PyXiaomiGateway] Got error element in data {"error":"Invalid key"}
2017-10-04 20:49:56 ERROR (SyncWorker_18) [PyXiaomiGateway] Got error element in data {"error":"Invalid key"}
2017-10-04 20:50:04 ERROR (SyncWorker_4) [PyXiaomiGateway] Got error element in data {"error":"Invalid key"}
i’m running HA on an raspberry pi3, 10.0.0.11 is my notebook from which i configure pi.
Did you guys manage to find the issue, I have the same errors.
The gateway is basically just acting as a bridge, I can’t interact play ringtones, switch on gateway light etc.
2017-10-12 21:38:38 ERROR (Thread-2) [PyXiaomiGateway] Got error element in data {“error”:“Invalid key”}
Does your router definitely support multicast?
If not then I understand that the GW will not work.
Not sure if you’d even get as far as you have with out multicast, but worth mentioning…
@syssi - who maintains the component docs for xiaomi_aqara?
It might be worth updating to include mention of the multicast requirement - I dont see it there.
I dunno if some router can enable/disable multicast. But i’m sure that there are someones, that block multicast, and then the gateway can’t be discovered.
In my case i have a livebox, that this one blocked me the multicast and i needed to chage it by other one.
