ok, thanks, i’ll try in the evening!
well, this did not work either, formatting was the same, i have just added: discovery_retry: 10
Do you know the ip of your gateway? Just extend the configuration:
xiaomi_aqara:
gateways:
- host: 192.168.x.x
mac: 286c078882xx
key: xhebx....
oh, thanks, that’s a new idea, i didn’t read about and try before! i’ll give it a try in the evening and let you know.
great, thanks! that was the thing i was looking for for a couple of days
it now shows the gateway on the start page, i see the status and can click to see the brightness level and the color, but i can’t change any of these. do you have a hint regarding this?
my log file says:
2017-10-04 20:48:58 WARNING (MainThread) [homeassistant.components.xiaomi_aqara] Static address (10.0.0.2:9898) of the gateway provided. Discovery of this host will be skipped.
2017-10-04 20:49:09 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-10-04 20:49:09 WARNING (MainThread) [homeassistant.setup] Setup of weather is taking over 10 seconds.
2017-10-04 20:49:13 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
2017-10-04 20:49:35 WARNING (SyncWorker_7) [netdisco.ssdp] Error fetching description at 10.0.0.11
2017-10-04 20:49:41 WARNING (SyncWorker_7) [netdisco.ssdp] Error fetching description at http://192.168.1.250:49152/description.xml
2017-10-04 20:49:50 ERROR (SyncWorker_3) [PyXiaomiGateway] Got error element in data {"error":"Invalid key"}
2017-10-04 20:49:56 ERROR (SyncWorker_18) [PyXiaomiGateway] Got error element in data {"error":"Invalid key"}
2017-10-04 20:50:04 ERROR (SyncWorker_4) [PyXiaomiGateway] Got error element in data {"error":"Invalid key"}
i’m running HA on an raspberry pi3, 10.0.0.11 is my notebook from which i configure pi.
Did you guys manage to find the issue, I have the same errors.
The gateway is basically just acting as a bridge, I can’t interact play ringtones, switch on gateway light etc.
2017-10-12 21:38:38 ERROR (Thread-2) [PyXiaomiGateway] Got error element in data {“error”:“Invalid key”}
unfortunately not. i think this thread might more interesting to you:
Does your router definitely support multicast?
If not then I understand that the GW will not work.
Not sure if you’d even get as far as you have with out multicast, but worth mentioning…
@syssi - who maintains the component docs for xiaomi_aqara?
It might be worth updating to include mention of the multicast requirement - I dont see it there.
Everybody is encouraged to update/change the docs. There is no maintainer in particular.
PR submitted
Merged.
Now you are just 3 pr from getting a free T-shirt
I’ve got it working on Openhab 2, i suspect my router is multicast enabled. Does anyone else have this issue that may have a multicast enabled router?
I dunno if some router can enable/disable multicast. But i’m sure that there are someones, that block multicast, and then the gateway can’t be discovered.
In my case i have a livebox, that this one blocked me the multicast and i needed to chage it by other one.
Thanks for the reply Garvarma, will move my secondary gateway to a different router and test and provide feedback.
I enabled my multicast and am still having the same issue as well as spotty performance from the button.
Spotty performance could indicate a range/signal strength issue.
The presses register in the Mi Home app, but are not always making it to HA.
Got a multicast enabled router and got problems (startet other, already referenced Thread) with error message “{“error”:“Invalid key”}”
