Xiaomi gateway integration - help needed
Same issue for me.
After sniffing with ngrep, it seems that the key value is not the same (don’t know if it’s normal or not).
for example:
my config:
xiaomi_aqara:
gateways:
- host: 192.168.1.22
mac: 34ce00906b44
key: 1z2z3z4e5r7t8t9g
discovery_retry: 10
Ngrep result:
U 192.168.1.21:58712 -> 192.168.1.22:9898
{“cmd”: “write”, “sid”: “34ce00906b44”, “data”: {“rgb”: 3036676095, “key”: “500c501be3cac0351efbbf11e7e28943”}}
U 192.168.1.22:9898 -> 192.168.1.21:58712
{“cmd”:“write_ack”,“sid”:“34ce00906b44”,“data”:"{“error”:“Invalid key”}"}
Sid seems to be the good value whereas the key is not.
The key from the config is encrypted first:
https://github.com/Danielhiversen/PyXiaomiGateway/blob/master/PyXiaomiGateway/init.py#L317
HA should receive a token from the gateway: https://github.com/Danielhiversen/PyXiaomiGateway/blob/master/PyXiaomiGateway/init.py#L170
If that is missing the encrypted key will be invalid.
Do you see any packages with token ?
No token in my traces.
Then you have the reason for the invalid key.
So you have to find what stops the packages to get from the gateway to HA.
Turn off the firewall and ensure your router supports multicast
Tested on my end, I’m using a totolink nr302 router with gateway connected wirelessly to router and pi over ethernet. Same issue invalid key. Anything else I can try?
Here is the trace:
U 192.168.1.21:35874 -> 192.168.1.22:9898
{“cmd”: “write”, “sid”: “34ce00906b44”, “data”: {“rgb”: 3036676095, “key”: “453cc0c71692ecde0474788b0f3c9da3”}}
U 192.168.1.22:9898 -> 192.168.1.21:35874
192.168.1.21 => HA
192.168.1.22 => Gateway Xiaomi
But you have received a package with the token during discovery of the gateway. Otherwise the gateway would not have shown up in HA:
https://github.com/Danielhiversen/PyXiaomiGateway/blob/master/PyXiaomiGateway/init.py#L214
Could you try ngrep port 9898 and start it before you start HA?
You should see multicast packages like this:
U 192.168.1.206:4321 -> 224.0.0.50:9898
  {"cmd":"heartbeat","model":"gateway","sid":"XXXXXXXXXXXX","short_id":"0","token":"XXXXXXXXX","data":"{\"ip\":\"192.168.1.206\"}"}
If you do not see these packages, I think there must be a network issue.
Indeed, i can see the token when i restart:
U 172.17.0.3:60517 -> 192.168.1.22:9898
{“cmd” : “get_id_list”}
U 192.168.1.21:60517 -> 192.168.1.22:9898
U 192.168.1.22:9898 -> 192.168.1.21:60517
{“cmd”:“get_id_list_ack”,“sid”:“34ce00906b44”,“token”:“ORMz9RvTpACmhCtw”,“data”:"[“158d0001ab1713”,“158d0001d62e82”,“158d0001d62f70”]"}
U 192.168.1.22:9898 -> 172.17.0.3:60517
{“cmd”:“read”,“sid”:“158d0001ab1713”}
Fyi, hass is in docker container.
It seems that you do not get any of the multicast packages.
So I think there is something with your network that blocks the multicast packages.
@wuns : Have you seen this? https://github.com/home-assistant/home-assistant/issues/8929#issuecomment-321887577
And this: https://github.com/home-assistant/home-assistant/issues/8355
Thank you @Danielhiversen.
My bad… I didn’t use --net=host for my docker run. Now it works!
Could you add a note describing your solution to the docs?
In the upper right corner of any documentation page, you will find “Edit this page on GitHub”. Follow the link and submit your suggested change. Demonstrated here: https://youtu.be/dRfk9JAlPJk?t=1h16m17s
@Danielhiversen done.
Great.
But I can not find your pull request.
What is your github username?
My username is jvimont. I edit the github page and “Propose file change”.
Am i right?
You forgot the last step.
Go to https://github.com/home-assistant/home-assistant.github.io/compare/current...jvimont:patch-1
And press Create pull request
Great, I will merge your pull request when the tests are finished.
3 more pull requests in October, and you will get a free T-shirt: https://home-assistant.io/blog/2017/09/29/hacktoberfest/
Hey everyone is there a way to Activate/Control the RGB portion of the Gateway’s light? HASS only sees it as a Normal Light not a Colour Light.
Ones you switched on light, then you can control brightness and colour.
When it’s off, then you can’t.
imagen
Hi @Danielhiversen. Thanks for the explanation. I ran the ngrep command and it seems those packages are also lost (results below). However, I have no idea how to fix it. I’m not using docker, I’m running HA on a Ubuntu Sever machine on Virtualbox. Any ideas? Thank you!
U 192.168.1.158:58941 → 192.168.1.190:9898
U 192.168.1.190:9898 → 192.168.1.158:58941
{“cmd”:“get_id_list_ack”,“sid”:“34ce008392d4”,“token”:“pYXWDM7yty4AbB38”,“data”:“["158d0001716fbc","158d0001228
96c","158d000183fa7a","158d0001225b3b","158d0001107e27","158d00016bfb96","158d000124408d"]”}
{“cmd”:“read”,“sid”:“158d0001716fbc”}
{“cmd”:“read_ack”,“model”:“plug”,“sid”:“158d0001716fbc”,“short_id”:7524,“data”:“{"voltage":3600,"status":"off
","inuse":"0","power_consumed":"240","load_power":"0.00"}”}
{“cmd”:“read”,“sid”:“158d000122896c”}
{“cmd”:“read_ack”,“model”:“motion”,“sid”:“158d000122896c”,“short_id”:33372,“data”:“{"voltage":3035,"status":"
motion"}”}
{“cmd”:“read”,“sid”:“158d000183fa7a”}
{“cmd”:“read_ack”,“model”:“magnet”,“sid”:“158d000183fa7a”,“short_id”:31442,“data”:“{"voltage":2995,"status":"
close"}”}
{“cmd”:“read”,“sid”:“158d0001225b3b”}
{“cmd”:“read_ack”,“model”:“switch”,“sid”:“158d0001225b3b”,“short_id”:10990,“data”:“{"voltage":3022}”}
{“cmd”:“read”,“sid”:“158d0001107e27”}
{“cmd”:“read_ack”,“model”:“cube”,“sid”:“158d0001107e27”,“short_id”:44228,“data”:“{"voltage":2975}”}
{“cmd”:“read”,“sid”:“158d00016bfb96”}
{“cmd”:“read_ack”,“model”:“switch”,“sid”:“158d00016bfb96”,“short_id”:4833,“data”:“{"voltage":3042}”}
{“cmd”:“read”,“sid”:“158d000124408d”}
{“cmd”:“read_ack”,“model”:“switch”,“sid”:“158d000124408d”,“short_id”:31253,“data”:“{"voltage":3022}”}
{“cmd”:“read”,“sid”:“34ce008392d4”}
{“cmd”:“read_ack”,“model”:“gateway”,“sid”:“34ce008392d4”,“short_id”:0,“data”:“{"rgb":0,"illumination":356,"pr
oto_version":"1.0.9"}”}
{ “cmd”:“read”,“sid”:“158d000122896c”}
motion"}”}
motion"}”}
motion"}”}
motion"}”}
motion"}”}
motion"}”}
You can also create scripts to turn on the light to a specific color.
purple_night_light:
  alias: Purple
    - service: homeassistant.turn_on
      entity_id: light.gateway_light_34ce008d4aae
        brightness: 255
        rgb_color: [88,0,82]
white_night_light:
  alias: White
        brightness: 255
        rgb_color: [255,255,255]
