I had 2 xiaomi V2 gateway with 51 devices (sensors, switches, …)
The sensors were evenly distributed among them.
Everything worked fine but one of them had burn (litterally!)
So, even if I had read that gateways devices are limited to 32, I’ve tested by myself and it work perfectly with Mii App and another domotic solution (jeedom).
But, since, it’s impossible to add this unique gateway to HA.
Autodiscovery work fine.
I’ve also try to configure it manualy: same error.
Here the log message
2020-08-20 16:10:29 DEBUG (SyncWorker_13) [xiaomi_gateway] _send_cmd >> b'{"cmd":"read","sid":"f0b429cc3e9f"}'
2020-08-20 16:10:29 DEBUG (SyncWorker_13) [xiaomi_gateway] _send_cmd resp << {'cmd': 'read_ack', 'model': 'gateway', 'sid': 'f0b429cc3e9f', 'short_id': 0, 'data': '{"rgb":0,"illumination":378,"proto_version":"1.1.2"}'}
2020-08-20 16:10:29 INFO (SyncWorker_13) [xiaomi_gateway] Discovering Xiaomi Devices
2020-08-20 16:10:29 DEBUG (SyncWorker_13) [xiaomi_gateway] _send_cmd >> b'{"cmd" : "get_id_list"}'
2020-08-20 16:10:30 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 73, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 145, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 60, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 106, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 153, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 201, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/xiaomi_aqara/config_flow.py", line 90, in async_step_user
self.selected_gateway = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/site-packages/xiaomi_gateway/__init__.py", line 234, in __init__
if self._discover_devices():
File "/usr/local/lib/python3.8/site-packages/xiaomi_gateway/__init__.py", line 241, in _discover_devices
resp = self._send_cmd(cmd, "get_id_list_ack") if int(self.proto[0:1]) == 1 \
File "/usr/local/lib/python3.8/site-packages/xiaomi_gateway/__init__.py", line 341, in _send_cmd
resp = json.loads(data.decode())
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xd0 in position 1008: invalid continuation byte
Anyone else has encountered this problem ?
Is ther a solution ?
Thank by advance for your help.
Edit: Adding the complete xiaomi_aqara log
