Anyone else have the issue of the gateways light sensor giving the readings back to front.?
If I increase the brightness it drops down to 120lm then when I close the blinds it goes up to 926lm.
Is this happening for anyone else?
Hmm, not me. Although I have experienced “reversing” issues with HA before, showing off icons when state was on and vice-versa. Removing and re-installing the component fixed it for me, try that!
I’ve noticed that the Xiaomi Gateway reports the previous lumens value when there is a change in brightness.
Never figured out how to work with this though.
It seems better then before after re-installing the component…but it still is not accurate at all. Anyone know a good light sensor that works with this gateway? Thanks for the advice so far
