So I’ve been using HA on Docker (DSM), for a couple of years.
I had to completely wipe out my HA docker container, and set it up from scratch. But I saved my configurations before. But the problem is, HA is no longer detecting the Xiaomi Aqara Gateway (1st gen).
I’m using:
xiaomi_aqara:
discovery_retry: 10
gateways:
- key: a2gj3vdcsb2tlnpx
But I always get:
2020-02-23 12:27:17 WARNING (MainThread) [homeassistant.setup] Setup of xiaomi_aqara is taking over 10 seconds.
2020-02-23 12:27:57 ERROR (SyncWorker_4) [homeassistant.components.xiaomi_aqara] No gateway discovered
2020-02-23 12:27:57 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi_aqara: Integration failed to initialize.
I’ve rebooting everything, but no matter what I do I can’t get the gateway to be detected.
If I put it like this:
xiaomi_aqara:
interface: '192.168.1.78'
gateways:
- mac: 34ce009074ae
I get,
2020-02-23 12:45:25 ERROR (MainThread) [homeassistant.setup] Error during setup of component xiaomi_aqara
File “/usr/src/homeassistant/homeassistant/setup.py”, line 174, in _async_setup_component
component.setup, hass, processed_config # type: ignore
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/xiaomi_aqara/init.py”, line 145, in setup
xiaomi.discover_gateways()
File “/usr/local/lib/python3.7/site-packages/xiaomi_gateway/init.py”, line 47, in discover_gateways
_socket.bind((self._interface, 0))
OSError: [Errno 99] Address not available
I don’t need to say that I’m absolutely sure that the gateway is on that IP, despite the message…
What can I do?
