First, you can’t configure the gateway through YAML anymore in 0.112.x.
Second, you already posted the links to the issues on github and the dev is working on a fix as far as I can see. Now be patient and wait for the fix to be merged. What do you expect?
Thank you very much for your answer. I adjusted the configuration in the old version 0.111.2 and changed the configuration as follows:
To enable Xiaomi Gateway (Aqara) in your installation, go to **Configuration** in the sidebar, then click **Integrations** . Xiaomi Aqara gateways should be discovered automatically and should show up in the overview. Hit configure and go through the steps to specify the optional settings. If your aqara gateway does not show up automatically, click the + icon in the lower right. Then search for “xiaomi_aqara” and enter the setup. Multiple gateways can be configured by simply repeating the setup multiple times.
This has worked so far. But after the upgrade I had the problem again. After that I worked with the keys again. Now it looks like this and it works so far.
strangely enough, he finds Xiaomi Miio devices, although I only use gateways. I have now deleted them again and Xiaomi Getway is running with the old keys which works quite well so far. It looks like this now.
