i have a xiaomi gateway V3, i have search for days…nothing found : Does this gateway give an entity “gateway” when you integrate it in hassio?
Because i have only all the sensors, no entity “gateway” so i cant use “alarm panel” to arm/desarm on hassio.
I have a Aqara Hub (compatible Home Kit) so its a V1 i think, when i integrate it with discovery:
i have an entity called “Aqara Hub 3710” and i can manage it with the card “alarm panel” and of course use arm function.
I am very disappointed because on my Aqara i cant see the door sensor and temperature sensors but i can manage the hub, and with the mio gateway V3 i see all sensors but can’t manage the gateway…
Thanks a lot for a response, for those it works, about this entity “xiaomi_aqara” that i have never seen as entity, like in the exemple at the end of the pahe here : https://www.home-assistant.io/components/xiaomi_aqara/
thanks a lot!
