Hi!
I’d like to buy a Xiaomi gateway and sensors.
Looking at HA Xiaomi component help it says:
Supported Devices
- Xiaomi Mijia Gateway
Unsupported devices:
- Xiaomi Aqara Gateway
And if you look at the way to add a Xiamoi gateway into conf.yaml it says that you need to add ‘xiami_aqara’ entry…
It is a little bit confusing…
Then which one should I buy ? an Aqara gateway ? or a Mija gateway ?
Then when it comes to sensors, for example temperature, on the internet you can find Mija and Aqara sensors… Are they all compatible together ? Will they all work with HA ?
If I buy a Mija gateway, will I be able to link Aqara sensors and see them into HA ?
