I also have a humidifier of the 2nd version (zhimi.humidifier. ca4). The standard integration does not have the water_level attribute. Although this attribute is described in the documentation.
Hey @edozat1,
I canāt help you, but maybe u can (sorry to disapoint you ).
Would you mind to share the entries you made in the config.yaml and the code you wrote in the card in you Lovelace UI?
Regards
@Magix3D Itās been a while, but I think I took the following steps:
Start with this guide: Xiaomi Miio - Home Assistant to get a token from the mi-home app. I used BlueStacks.
Add this repository in HACS: GitHub - syssi/xiaomi_airpurifier: Xiaomi Mi Air Purifier and Xiaomi Mi Air Humidifier integration for Home Assistant
Add this to you config.yaml:
fan:
- platform: xiaomi_miio
host: !secret host_ip
token: !secret xiaomi_humidifier_token
model: zhimi.humidifier.ca4
Now you should have the fan entity
- The card is a custom card in HACS: GitHub - artem-sedykh/mini-humidifier: Minimalistic humidifier card for Home Assistant Lovelace UI
Hope this helps
@edozat1 Thank you, and how did you manage to get the humidifier working with the custom card?
My current problem is, that I add the entities one for one to my config.yaml like this:
fan:
# Antibacterial Humidifier
- platform: xiaomi_miio_airpurifier
name: Antibacterial Humidifier
host: secretip
token: secrettoken
model: deerma.humidifier.jsq
switch:
platform: template
switches:
airhumidifier_temperature_buzzer:
friendly_name: Air Humidifier Buzzer
value_template: "{{ is_state_attr('fan.antibacterial_humidifier', 'buzzer', True) }}"
turn_on:
service: xiaomi_miio_airpurifier.fan_set_buzzer_on
entity_id: fan.antibacterial_humidifier
turn_off:
service: antibacterial_humidifier.fan_set_buzzer_off
icon_template: mdi:volume-high
platform: template
sensors:
airhumidifier_temperature:
friendly_name: Air Humidifier Temperature
value_template: '{{ states.fan.antibacterial_humidifier.attributes.temperature }}'
unit_of_measurement: 'Ā°C'
airhumidifier_humidity:
friendly_name: Air Humidifier Humidity
value_template: '{{ states.fan.antibacterial_humidifier.attributes.humidity }}'
unit_of_measurement: '%'
icon_template: mdi:water-percent
airhumidifier_buzzery:
friendly_name: Air Humidifier Sound
airhumidifier_water_tank_detached:
friendly_name: Air Humidifier Water Tank
value_template: '{{ states.fan.antibacterial_humidifier.attributes.water_tank_detached }}'
icon_template: mdi:water-boiler
The custom card doesnāt recognise anything though.
I can add these entities manually to my UI and they work, but not with the card.
@Magix3D Right, step 5 is missingā¦
When youāve added the custom card in HACS, you can add a manual card with the following config:
type: 'custom:mini-humidifier'
entity: fan.friendlyname
Hey @syssi,
since you apparently know a few things (:P) - do you happen to know what @edozat1 and me can do about the issue, that the water level isnāt showing in the mini-humidifier-card?
Regards
@Magix3D Please contact the author of the custom card and ask for deerma.humidifier.jsq
support. It looks like the custom card doesnāt support all versions out of the box:
Good idead - Iāll do that - thank you
hey folks got mine humidifier today, is anybody out there who got it working in different subnets/VLANs? I already saw that this might cause in errors, but that there are a few of ppl got it working.
fan:
host: 192.168.180.31
token: XXXXXXXXX
I ran into error below:
logger: custom_components.xiaomi_miio_airpurifier.fan
Source: custom_components/xiaomi_miio_airpurifier/fan.py:1664
Integration: xiaomi_miio_airpurifier ([documentation](https://github.com/syssi/xiaomi_airpurifier), [issues](https://github.com/syssi/xiaomi_airpurifier/issues))
First occurred: 16:16:25 (1 occurrences)
Last logged: 16:16:25
Got exception while fetching the state: Unable to discover the device 192.168.180.31
I just did it yesterday for the deerma.humidifier.jsq
, it works with this HACS integration (cloud): hass-xiaomi-miot/README.md at master Ā· al-one/hass-xiaomi-miot Ā· GitHub
Aside from the device itself, the entities exposed are:
- Humidity Sensor
- Temperature Sensor
- Light (its LED)
You can turn it on/off and set a target humidity.
I was a bit disappointed that there is no water tank level, not sure if itās a limitation of the hardware or of the integration, but itās missing also from the app.
If anyone knows how to bypass the cloud account and go for local control only, Iām all ears.
EDIT: HA and the Humidifier are on separate VLANs
Did you find a solution?
I get the same error in the logs and the fan shows as unavailable in Developer Tools.
Only difference is I run everything on the same routher with no subnetās.
Water tank is added in the next HA release
No solution for different vlans, I brought it to the same vlan as the HA server
This model will be supported by the core integration after 2021.9 release Xiaomi Miio - Home Assistant
My deerma.humidifier.jsq is realy unreliable (see screenshot). I have tested it with both syssiās xiaomi_airpurifier custom component and the Xiaomi Miio core integration.
When it works, it work well and I canāt say one integration is different from the other on this matter. Also thereās no problem in Mi Home app.
Home assistant log:
2021-09-06 15:09:35 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Mi Smart Antibacterial Humidifier' for xiaomi_miio integration not ready yet: Unable to discover the device 192.168.1.125; Retrying in background
2021-09-06 15:43:03 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Timeout fetching Mi Smart Antibacterial Humidifier data
Iām trying to add an Xiaomi mi antibacterial humidifier, it should be supported itās an deerma.humidifier.jsq5.
This is my config:
fan:
host: ip_address
token: token
model: deerma.humidifier.jsq5
But in de logging i am getting this error:
Got exception while fetching the state: Unable to discover the device ip_address
With extra debug logging on i get no extra messages.
What can be the problem?
Iām using this integration with hacs:
same,
Any news with deerma.humidifier.jsq5 support?
I have it working with the hacs integration Xiaomi Miot Auto.
Extracten the key with the extractor tool and added it local.
