I managed to configure the remote by retrieving the token and everything. got it to learn ir RAW from remote. but when i try to send command, i got error (magic error -5008) . tried removing one and both ‘=’ at the end. search around finds that removing space between RAW and codes helps, but mine nvr had space in the first place. i m at lost now.
any solutions?
I have the same error…
i managed to get it to work by re-capturing the ir again. apparently, previously, the raw code wasnt complete.
You need to add “commands:” before command list.
