Xiaomi JY-GZ-01AQ smoke detector battery status
Hi all.
I got a Xiaomi JY-GZ-01AQ smoke detector a few weeks ago. It started beeping indicating that the battery was low, even if it is brand new, so I changed the battery to a fresh one. Still, the battery status in HA is 0%, and the detector beeps indicating that the battery is low.
I updated the FW following this guide:
Using a FW file from:
https://github.com/Koenkk/zigbee-OTA/tree/master/images/Xiaomi
I’ve tried re-adding the smoke detector.
Has anyone else encountered this? Or know of any fix?
Same issue for me, did you find a solution?
Yes, I got a new one on warranty and the new one is fine.
I got this from the Aqara brand and experienced the same with Z2M. Upgrading Z2M fixed that (a wrong conversion from voltage to % was used, so they only appreared to be low on battery)
