I have set up a light sensor successfully via Phoscon/Deconz (using Conbee II) and changes in light are being reflected, as can be seen from the 2 images below.
However, The Home Assistant/Lovelace side appears to be stuck at one luminance reading of 14. It never changes, whether in a Lovelace card in overview or actually at the Integration/Devices screen.
Note that I did rename the sensor in Phoscon very early on so this has not helped withmatching things up.
This leads me to 2 possibilities, both of which, I do not know how to debug:
This is not the same entity in Lovelace. This is an outside possibility as I did have another sensor previously, which I have misplaced, but I am certain it has been removed from Deconz. There is a ghost light sensor in Devices that I cannot remove and is showing as unavailable.
There needs to be some tweaking to ensure the Deconz values do get passed to the Home Assistant front end.
Deconz does show a mac address so I was hoping I could check this somewhere in HA to make sure any Lovelace is picking up the correct device.
