Received these very small, very unobtrusive battery-powered PIR sensors this evening, and quickly paired two of them with the iPhone app and my Aqara Gateway. I’m guessing they should appear as binary_sensor entities, but what events do they fire? Is it just a state change from on to off and back again?
I forgot to mention, it paired easily with the gateway, but no new entities ever showed up anywhere in Home Assistant.
Yes the state changes to on as soon as motion is detected, and off if no motion after 60s. They do have a built in timer that reports as an attribute that I use for a timer.
No motion since: 300
I had no issue with them showing up in HA. What hub are you using? Does it have a light on it? Do you have an illumination sensor from the hub as a registered entity?
