Xiaomi LYWSD03MMC BLE Temperature and Humidity Display
I recently purchased one of these very cheap displays.
Xiaomi_LYWSD03MMC
I hoped to pick up the readings in my Home Assistant. After some digging, I found that someone had managed to interface a Raspberry PI to it. From there it was plain sailing.
You can find my code and instructions on GitHub here https://github.com/AnthonyKNorman/Xiaomi_BLE_Temperature_Display_for_HA
but how to use in Hassio. there is not
systemd so you cant start a service like:
sudo systemctl enable blemqtt
I run it on a separate Raspberry Pi Zero W.
I don’t see support for this model in openmqttgateway? Can you provide a link?
This is great - many thanks. It worked first time.
If anyone is trying to use it with Openhab, here are the entries from my .items file that use the MQTT interface.
Number	Utility_Room_TempHumBLE_Sensor_Temperature 		"Utility Room BLE_Sensor:Temperature [%.1f C]"		<temperature> (gIndoorTemps,gTemp,Temperature,gTemperature,gHistory)	[ "Current Temperature" ]
{mqtt="<[mysensorsMQTT:blemqtt/sensor01:state:JSONPATH($.temperature)]" }
Number	Utility_Room_TempHumBLE_Sensor_Humidity 		"Utility Room BLE_Sensor:Humidity [%.1f C]"		<humidity>	(gUtilityRoom,gIndoorHumidity,Humidity,gHistory)	[ "Current Humidity" ]
{mqtt="<[mysensorsMQTT:blemqtt/sensor01:state:JSONPATH($.humidity)]" }
Any chance of extending the script to support multiple sensors?..
I wish it can be directly integrated with home assistant core integrations as BLE present on Raspberry PI 3B+ and above.
It’s integrated with HACS Xiaomi BLE integration. Just read docs for it.
Thanks @Szaman
I have now amended the scripts to support multiple sensors.
Great solution, but how to connect to mqtt with user and password?
If you have a look in the closed issues on github this has already been resolved. At some point I will add it to the parameters.
Thanks! I always forgetting about closed issues :man_facepalming:
Original script was modified for less energy usage, will you rewrite your code?
Latest version carries this modification.
Is it possible to run it on the same device where i have HA? or I need to buy other RPi?
I have only run this on a separate Raspberry Pi zero w. They are quite cheap. I have a prototype running using an ESP32 as the hub. This will make it very cheap. I will be posting this soon!
Tahnk you very much for your answer. I asked bcs right now I jave got only one RPi.
Running this chip on ESP32 is the best idea ( the cheapest and the lowest power consumption solution), It will be possible launch more than one sensor?
Yes. It supports up to twenty sensors.
I have posted about my esp32 code now https://github.com/AnthonyKNorman/Xiaomi_LYWSD03MMC_for_HA
How to connect to mqtt with user and password ?
The script has only the server address.
