I had an esp32s connected to 2x Xiaomi LYWSD03MMC temperature and humidy sensors. The esp32s died a couple of weeks ago so I replaced it with a new one. This showed up in the dashboard fine once I added the location and disabled the failed unit (not sure how to remove it).
However after some recent updates to Home Assistant and ESPHome all the values show as “Unavailable” both in the dashboard and in a Grafana dashboard.
If I view the logs you can see that it has no problem with retrieving the values:
[08:52:15][D][esp32_ble_tracker:180]: Starting scan…
[08:52:29][D][esp32_ble_tracker:620]: Found device A4:C1:38:D0:71:87 RSSI=-80
[08:52:29][D][esp32_ble_tracker:641]: Address Type: PUBLIC
[08:52:29][D][esp32_ble_tracker:643]: Name: ‘LYWSD03MMC’
[08:52:48][D][xiaomi_ble:313]: Got Xiaomi LYWSD03MMC (A4:C1:38:D0:71:87):
[08:52:48][D][xiaomi_ble:316]: Temperature: 13.2°C
[08:52:48][D][sensor:131]: ‘Temperature #2’: Sending state 13.20000 °C with 1 decimals of accuracy
[08:53:44][D][esp32_ble_tracker:620]: Found device A4:C1:38:48:68:BF RSSI=-76
[08:53:44][D][esp32_ble_tracker:641]: Address Type: PUBLIC
[08:53:44][D][esp32_ble_tracker:643]: Name: ‘LYWSD03MMC’
[08:55:36][D][xiaomi_ble:313]: Got Xiaomi LYWSD03MMC (A4:C1:38:48:68:BF):
[08:55:36][D][xiaomi_ble:319]: Humidity: 86.0%
[08:55:36][D][sensor:131]: ‘Humidity’: Sending state 86.00000 % with 0 decimals of accuracy
Can anyone give this noob some pointers on how to troubleshoot this?
Cheers
David
