Hello, i’ve got a problem with the xiaomi magic cube and deconz. I’am fine with listening to the deconz_event and i get all the events, when i flip, rotate and shake the button.
For easy use, i want a sensor, which indicates the upper side of the cube. I made an input_select, which the following options and a sensor. For example, when deconz_event fire 6002,6003,6004 i want, that the sensor option is seite6. When deconz_event fire 3002,3003,3004,3005 than option should be seite 3. Could anybody give me an advice. Thank you
input_select:
cube2_seite_oben:
name: Cube2 Seite oben
options:
- seite1
- seite2
- seite3
- seite4
- seite5
- seite6
initial: seite1
cube2_seite_oben:
entity_id:
- input_select.cube2_seite_oben
value_template: '{{ states.input_select.cube2_seite_oben.state}}'
friendly_name: 'Cube2 Seite oben'
