Not sure what you mean by purifier token or gateway token. The token is in the ‘token’ field of the logs you retrieve from the app on your phone. Check https://github.com/Maxmudjon/com.xiaomi-miio/blob/ed0428f96ab3fdaa26fffacd864681c9496aa267/docs/obtain_token.md for details
I have the same issue.
Did you find a solution?
Also I managed to find this nice guide on how to get the other sensors to appear.
However in mine I had to tweak the layout and some of the spacing to get it to work
sensors:
air_purifier_aqi:
friendly_name: "PM2.5"
unit_of_measurement: 'μg / m³'
value_template: "{{state_attr ('fan.air_purifier', 'aqi')}}"
air_purifier_temperature:
friendly_name: "Temperature"
unit_of_measurement: '° C'
value_template: "{{state_attr ('fan.air_purifier', 'temperature') | float | round (2)}}"
air_purifier_humidity:
friendly_name: "Humidity"
unit_of_measurement: '%'
value_template: "{{state_attr ('fan.air_purifier', 'humidity')}}"
air_purifier_speed:
friendly_name: "Mode"
value_template: "{{state_attr ('fan.air_purifier', 'speed')}}"
air_purifier_favorite_level:
friendly_name: "Favorite Level"
value_template: "{{state_attr ('fan.air_purifier', 'favorite_level')}}"
air_purifier_motor_speed:
friendly_name: "Motor Speed"
unit_of_measurement: 'rpm'
value_template: "{{state_attr ('fan.air_purifier', 'motor_speed')}}"
That did the trick . For some reason, my token was wrong. got it using an old MiHome app and it seems it was not right. Or it has changed after I got it…
THANK YOU VERY MUCH!!!
Hi guys, I have created here a complete card for 3H: Lovelace: Xiaomi - Mi air purifier 3H card. Next step is to translate in something more compact.
Thank you for sharing your work.
I’ve managed to add sensors for my Mi Air Purifier 3H but somehow I get value “none” for all sensors.
Here is my code:
sensors:
mi_air_purifier_temp:
value_template: "{{ state_attr('fan.xiaomi_airpurifier_3h', 'temperature') }}"
unit_of_measurement: "°C"
device_class: "temperature"
mi_air_purifier_humidity:
value_template: "{{ state_attr('fan.xiaomi_airpurifier_3h', 'humidity') }}"
unit_of_measurement: "%"
device_class: "humidity"
mi_air_purifier_air_quality_pm25:
friendly_name: "Air quality (AQI) PM2.5"
value_template: "{{ state_attr('fan.xiaomi_airpurifier_3h', 'aqi') }}"
unit_of_measurement: "μg/m³"
icon_template: "mdi:weather-fog"
mi_air_purifier_avg_air_quality_pm25:
friendly_name: "Average air quality (AvgAQI) PM2.5"
value_template: "{{ state_attr('fan.xiaomi_airpurifier_3h', 'average_aqi') }}"
icon_template: "mdi:weather-hazy"
mi_air_purifier_use_time:
friendly_name: "Time used"
value_template: >
{% macro phrase(value, name) %}
{%- set value = value | int %}
{%- set end = 's' if value > 1 else '' %}
{{- '{} {}{}'.format(value, name, end) if value | int > 0 else '' }}
{%- endmacro %}
{% set weeks = (state_attr('fan.xiaomi_airpurifier_3h', 'use_time') | int / 604800) | int %}
{% set days = ((state_attr('fan.xiaomi_airpurifier_3h', 'use_time') | int - (weeks * 604800)) / 86400) | int %}
{% set hours = ((state_attr('fan.xiaomi_airpurifier_3h', 'use_time') | int - (weeks * 604800) - (days * 86400)) / 3600) | int %}
{% set minutes = ((state_attr('fan.xiaomi_airpurifier_3h', 'use_time') | int - (weeks * 604800) - (days * 86400) - (hours * 3600)) / 60) | int %}
{% set seconds = (state_attr('fan.xiaomi_airpurifier_3h', 'use_time') | int - (weeks * 604800) - (days * 86400) - (hours * 3600) - (minutes*60)) | int %}
{{ [ phrase(weeks, 'week'), phrase(days, 'day'), phrase(hours, 'hr'), phrase(minutes, 'min'), phrase(seconds, 'sec') ] | select('!=','') | list | join(', ') }}
icon_template: "mdi:heart-pulse"
mi_air_purifier_filter_used:
friendly_name: "Filter used"
value_template: "{{ state_attr('fan.xiaomi_airpurifier_3h', 'filter_hours_used') }}"
unit_of_measurement: "hrs"
icon_template: "mdi:heart-off"
mi_air_purifier_filter_remaining:
friendly_name: "Filter remaining"
value_template: "{{ state_attr('fan.xiaomi_airpurifier_3h', 'filter_life_remaining') }}"
icon_template: "mdi:heart-outline"
mi_air_purifier_purify_volume:
friendly_name: "Purified volume"
value_template: "{{ state_attr('fan.xiaomi_airpurifier_3h', 'purify_volume') }}"
unit_of_measurement: "m³"
icon_template: "mdi:warehouse"
mi_air_purifier_speed:
friendly_name: "Motor speed"
value_template: "{{ state_attr('fan.xiaomi_airpurifier_3h', 'motor_speed') }}"
unit_of_measurement: "rpm"
icon_template: "mdi:speedometer"
mi_air_purifier_led_brightness:
friendly_name: "Led brightness"
value_template: "{{ state_attr('fan.xiaomi_airpurifier_3h', 'led_brightness') }}"
unit_of_measurement: "lx"
icon_template: "mdi:brightness-5"
Any idea?
Thank you.
Check the platform definition
fan:
- platform: xiaomi_miio
name: “Mi Air Purifier 3H”
then you should use fan.mi_air_purifier_3H. Or you could use as name Xiaomi Airpurifier 3H
For me, I have another issue. It show fine the values. But it only updates when i restart hassio. Not when a change happens. Why is that? Do I need something else or what could be missing?
Thank you spotting it. That was exactly the issue.
Regarding availability blinking. I have the same issue and I opened corresponding ticket at core repo: https://github.com/home-assistant/core/issues/36972
Also I’ve created another thread on forum: Miio Xiaomi Air Purifier availability blinking
I’ve seen the “official” integration for the various Air Purifiers, including the 3 and 3H, but I do not use the Xiaomi Gateway.
I haven’t found a way to retrieve the “token” to be able to integrate the Air Purifier 3. Does anyone know how this can be retrieved,as the official integration seems to have all the functions I need. I just can’t seem to get the token needed to make it work.
Been trying to get my 3H to connect with home assistant without much luck. I only get “Unable to discover a device” errors in the logs.
If I run miiocli on a different computer, I can successfully pull all details from the device so the token is correct. Command I’m using:
miiocli -d airpurifiermiot --token <token> --ip <ip> status
The HA component however just says unable to discover device, configuration below.
host: <my ip address>
token: <my token>
model: zhimi.airpurifier.mb3
name: Xiaomi Air Purifier 3H One
If I go into portainer and run the exact same miiocli command from above from the HA container, a python exception is thrown
INFO:miio.cli:Debug mode active
DEBUG:miio.miioprotocol:Unable to discover a device at address <ip address>
DEBUG:miio.click_common:Exception: Unable to discover the device <ip address>
File "/usr/local/lib/python3.8/site-packages/miio/click_common.py", line 59, in __call__
return self.main(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 782, in main
rv = self.invoke(ctx)
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 1259, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 1066, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/local/lib/python3.8/site-packages/click/core.py", line 610, in invoke
return callback(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/miio/click_common.py", line 280, in wrap
kwargs["result"] = func(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/click/decorators.py", line 73, in new_func
return ctx.invoke(f, obj, *args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/miio/click_common.py", line 245, in command_callback
return miio_command.call(miio_device, *args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/miio/click_common.py", line 193, in call
return method(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/miio/airpurifier_miot.py", line 300, in status
for prop in self.get_properties_for_mapping()
File "/usr/local/lib/python3.8/site-packages/miio/miot_device.py", line 29, in get_properties_for_mapping
return self.get_properties(
File "/usr/local/lib/python3.8/site-packages/miio/device.py", line 232, in get_properties
values.extend(self.send(property_getter, _props[:max_properties]))
File "/usr/local/lib/python3.8/site-packages/miio/device.py", line 146, in send
return self._protocol.send(
File "/usr/local/lib/python3.8/site-packages/miio/miioprotocol.py", line 160, in send
self.send_handshake()
File "/usr/local/lib/python3.8/site-packages/miio/miioprotocol.py", line 87, in send_handshake
raise DeviceException("Unable to discover the device %s" % self.ip)
The miiocli version is 0.5.3 in both cases so I have no idea what is different in the HA container that causes it to fail. I can ping the purifier from the docker container so I didn’t think it was a network issue.
Hoping someone can shed light on this.
Did you already solve this?
I’m having the same issue, I’m not able to communicate with the device through miiocli, but the Mi Home app works, I’ve extracted the token from there.
Unfortunately no I’m still stuck. Are you able to connect through miiocli on a separate machine to HA at all, or not at all?
I wasn’t able to connect at all.
In my case it was apparently because the purifier is on a different subnet.
Made a rule in my Unifi config and now it works!
I’m afraid I’m not a docker user so your issue is different than mine.
Maybe also some network rules have to be applied in your case?
Interesting, my HA instance is actually on a different subnet, when i tested using the miicli too on a different machine I was probably on the same subnet as the purifier.
I also have a unifi router + wap, mind sharing what changes you made? Thanks! I thought because I could ping there wasn’t a network issue, maybe there is!
you might need the mihack app
Or just read the complete thread, I posted links to how to acquire the token.
