Xiaomi Mi Camera 2k (Magnetic Mount) isa.camera.hlc7 Streaming?
is it possible to stream from this camera on home assistant?
Entities imported into home assistant:
Indicator Light Switch
Motion Detected
Control Switch
Motion event whit image
Camera control (stream no send image)
were you able to add the camera to home assistant?
only what you see above. The stream is not available.
The only option is to flash the original camera using this link:
https://github.com/kasitoru/mjsxj02hl_firmware
But you lose the record on the sd card
