Xiaomi Mi Cube After 0.77 update changed name
Yesterday I updated my system from 0.76.x to 0.77.3.
All my Xiaomi cubes (old version, not the Aqara) have “_2” as suffix, now.
Is this normal ?
EDIT:
I see that in core.entity_registry, about the same cube, I have:
                "config_entry_id": null,
                "device_id": null,
                "entity_id": "binary_sensor.cube_158d0001XXXXXX",
                "name": null,
                "platform": "xiaomi_aqara",
                "unique_id": "cube158d0001XXXXXX"
and
            "device_id": null,
            "entity_id": "binary_sensor.cube_158d0001XXXXXX_2",
            "name": null,
            "unique_id": "status158d0001XXXXXX"
Thanks!
Mine has the same thing which is probably why my cube automations no longer work :stuck_out_tongue:
Yes, change the name in the automation and it will work again!
But I don’t understand why the double name and if I can delete one.
Just copy the file and delete one of them and if it all works then you are OK, if not copy it back :slight_smile:
