I´m trying to collect xiaomi mi flora data from two sensors for a start.
But I can´t find out how.
I have identified the MAC addresses from my intel nuc (with updated Bluetooth drivers) on Debian 9, Hassio 0.92.2
The Mi floras are the international version (at least, that’s what I ordered)
battery
All the sensors are visible, but values are permanently Unavailable.
In home-assistant.log I get a lot of these:
“Updating miflora sensor took longer than the scheduled update interval 0:10:00”
“Update of sensor.jord1_temperature is taking over 10 seconds”
Questions:
What else do I have to do? Do I have to pair the sensors to my nuc? I tried but without any luck.
How far away from the server can the sensors be placed? It looks like they don´t reach very far.
Is there a way to extend the bliuetooth/BLE range that I can use? I will need several sensors up to 25 meters away and through walls/floors.
I waited more than minutes. It´s been days with no response.
To cover the whole field, I guess I´ll have to consider two or three RPis or maybe some NodeMCUs (which I have used for other projects).
With RPis, what´s the best way? Separate hassio installations and MQTT to the main server?
Maybe I can find a way for the NodeMCUs to read the sensors.
have a look at plantgateway - https://github.com/ChristianKuehnel/plantgateway - then you can offload the interfacing to one or more RPI zero W, and use MQTT to push the data to your HASS install.
Do you have access to the syslog on the NUC - grep it for miflora and see if anything going on there.,…
Be warned - bluetooth and 2.5Ghz wifi can clash as they may be on similar frequencies - I gave up using a RPIzero and a bluetooth presence detector for this reason (but the plantgateway works great as as it polls then sends)
I tried this on a RPi3B.
When I run plantgateway I get:
/usr/local/lib/python3.5/dist-packages/plantgw/plantgw.py:33: YAMLLoadWarning: calling yaml.load() without Loader=… is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details.
config = yaml.load(config_file)
Sun, 26 May 2019 12:22:13 INFO PlantGateway version 0.5.1
Sun, 26 May 2019 12:22:13 INFO loaded config file from /home/pi/.plantgw.yaml
Sun, 26 May 2019 12:22:13 INFO Getting data from sensor jord1
Sun, 26 May 2019 12:22:13 ERROR could not read data from C4:7C:8D:6A:B0:B4 (jord1) with reason: [Errno 111] Connection refused
File “/usr/local/lib/python3.5/dist-packages/plantgw/plantgw.py”, line 212, in process_all
self.process_mac(sensor)
File “/usr/local/lib/python3.5/dist-packages/plantgw/plantgw.py”, line 190, in process_mac
self._publish(sensor_config, poller)
File “/usr/local/lib/python3.5/dist-packages/plantgw/plantgw.py”, line 163, in _publish
self.start_client()
File “/usr/local/lib/python3.5/dist-packages/plantgw/plantgw.py”, line 137, in start_client
self._start_client()
File “/usr/local/lib/python3.5/dist-packages/plantgw/plantgw.py”, line 159, in _start_client
self.mqtt_client.connect(self.config.mqtt_server, self.config.mqtt_port, 60)
File “/usr/local/lib/python3.5/dist-packages/paho/mqtt/client.py”, line 839, in connect
return self.reconnect()
File “/usr/local/lib/python3.5/dist-packages/paho/mqtt/client.py”, line 962, in reconnect
sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
File “/usr/lib/python3.5/socket.py”, line 712, in create_connection
raise err
File “/usr/lib/python3.5/socket.py”, line 703, in create_connection
sock.connect(sa)
I get this for both sensors. What am I doing wrong?
Helge
