Xiaomi Mi Smart Pedestal Fan
after latest installation of home assistant, the damianpasek/xiaomi_fan for dmaker.fan.1c not work. is possible implement in xiaomi miio? thanks a lot
I was using this one : GitHub - syssi/xiaomi_fan: Xiaomi Mi Smart Fan integration for Home Assistant
and it’s also broken.
Maybe @syssi can help ?
Unable to find referenced entities fan.xiaomi_smart_fan
The custom component isn’t broken. I assume the log message is harmless. The fan.dmaker.1c is supported now!
yes :slight_smile: now i can add the fan… but i receive this error:
Platform xiaomi_miio_fan not ready yet: Unable to discover the device 10.10.120.39; Retrying in background in 30 seconds
Setting is:
fan:
  - platform: xiaomi_miio_fan
    name: Xiaomi Smart Fan
    host: 10.10.120.39
    token: 60bc5f4d7b1af443dbc30f23044f39f6
the fan is in an other subnet - but HA can ping the Fan…
my xiaomi Vaccom is in the same VLAN and works :-/
do you have an idea?
Your vacuum is a full-featured linux machine. The Xiaomi Fan is ESP8266 based and somehow limited. The network stack / firmware of the device doesn’t support discovery across subnets: Troubleshooting — python-miio documentation
If you move the fan to the same subnet as HA it should work out of the box if the token is correct.
Thank you… after change in the same subnet - it works :slight_smile:
