This is my proposal for a fix
how to install this workaround? iāve changed xiaomi_plug.py but it canāt download the new mirobo component requiredā¦
If you want to mess up your setup: Just remove the REQUIREMENTS line and change your mirobo library manually. May be this is also interesting for people who like to do some testing:
This is the magic to avoid enforcement of the requirements at the startup of home assistant:
hass --skip-pip
And this is the patched library:
pip3 install "https://github.com/syssi/python-mirobo/archive/7e59aef7f9c6d09a6270e315890a75dc0e2f6fc7.zip#python-mirobo"
yes iāve alredy doneā¦ something similarā¦ i change the mirobo plug.py file manually and use 0.1.3 as requirements
I would be happy if you compare the measurements of both applications again.
waiting for homeassistant to startā¦ itās about 5 minutes nowā¦
Ok nowā¦
Smart strip 1:
- app says 35W
- HA says 28.6
Smart strip 2:
- app says 10W
- HA says 14.3
Strangeā¦
Puh. Could you do the proposed 60W light bulb test or do you own another device which can measure the load?
Iāll test it tonight. Not at home at the moment
When i come back home iāll test the light bulb
iāve tryed with a bulb of 15W
app says 14W
HA says 11
If you can provide pairs for different consumers / powers we try to build a calibration method.
Iām collecting mDNS device names of miio devices. Do you like to help? Please provide the output of
avahi-browse -a | grep miio
I need the prefixes only. You can remove the number after āmiioā. f.e.
+ wlan0 IPv4 yeelink-light-mono1_miioXXXXXXXX _miio._udp local
+ wlan0 IPv4 lumi-gateway-v3_miioXXXXXXX _miio._udp local
+ wlan0 IPv4 yeelink-light-color1_miioXXXXXXXX _miio._udp local
+ wlan0 IPv4 chuangmi-plug-m1_miioXXXXXXXX _miio._udp local
Thanks in advance!
Here you are some more:
+ eth0 IPv4 xiaomi-repeater-v1_miioXXXXXXXX _miio._udp local
+ eth0 IPv4 chuangmi-ir-v2_miioXXXXXXXX _miio._udp local
+ eth0 IPv4 lumi-gateway-v3_miioXXXXXXXX _miio._udp local
+ eth0 IPv4 zimi-powerstrip-v2_miioXXXXXXXX _miio._udp local
The xiaomi repeater is a wifi repeater?
Yes, it is. Although mine is the first version, there is a new version now and I donāt know the differences. I think the v2 has higher speed.
BTW: the Wifi Repeater has a property that tells the number of devices connected to it.
Do you know the property name?
+ eth0 IPv4 zhimi-airpurifier-m1_miioXXXXXXXX _miio._udp local
+ enp3s0 IPv4 zimi-powerstrip-v2_miioXXXXXXXX _miio._udp local
+ enp3s0 IPv4 yeelink-light-color1_miioXXXXXXXX _miio._udp local
+ enp3s0 IPv4 lumi-gateway-v3_miioXXXXXXXX _miio._udp local
+ enp3s0 IPv4 chuangmi-ir-v2_miioXXXXXXXX _miio._udp local
ec-blaster:BTW: the Wifi Repeater has a property that tells the number of devices connected to it.
Iām convinced it is conn_sta_num
, but I cannot guarantee:
root@orangepizero:~# miio --control 192.168.1.51 --method get_prop --params '["conn_sta_num"]'
INFO Attempting to control 192.168.1.51
ERROR Encountered an error while controlling device
Error was:
Method `get_prop` is not supported
