Xiaomi Miio Integration - Re-authentication was successful
Hello Everyone,
Today I was testing the native Miio integration, and I was able to get it to work both with manual configuration and cloud synchronization. However, because initially I could not get it to work due to the separate VLANs, I had to create a NAT. So, after the creation of the NAT rule on my firewall, I was able to successfully add the devices and control them locally.
However, I noticed that the device that I initially added and removed because it was not working (missing NAT rule), could not be added anymore, it was just giving the message: Re-authentication was successful. I tried several things to the point that I decided to remove all the devices in the Miio integration and reboot home assistant. Now, for all the devices that I previously added, I cannot add them anymore, I am simply getting the message: Re-authentication was successful.
I checked /root/homeassistant/.storage/core.config_entries already and cannot see the previously added devices here.
Any hint how I can get those devices added again?
I have the same problem. Did you fixed it?
