Hi all,
I was wondering why the Xiaomi Miio vacuum integration in Home Assistant is showing the maintenance sensors in seconds (see here )? When using the Xiaomi Home/Roborock app on my phone it shows all the maintenance items in hours, why does the Home Assistant integration converts this to (useless) seconds?
If you find another way to show the sensors in hours please share it with me!
Kind regards,
Darryl
tom_l
November 22, 2021, 3:32pm
2
A fix for this is in progress.
home-assistant:dev
← rytilahti:xiaomi_miio/fix/sensor_measurement_units
opened 05:23PM - 04 Nov 21 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
The sensor values are not reported anymore in the device native measurement unit (seconds),
but using a more suitable, sensor-specific units.
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
First try to make some saner default measurement units. I'm not sure if this is the way to go, so I'll mark this as a draft to get some feedback.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #59027
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [ ] The code change is tested and works locally.
- [ ] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [ ] No score or internal
- [ ] 🥈 Silver
- [ ] 🥇 Gold
- [ ] 🏆 Platinum
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
Ah ok great, I’ll just wait! Thanks!
Damn, the PR was never merged. How are people handlinkg this instead? Create your new sensors and calculate the time in hours on the fly?
tom_l
March 24, 2022, 9:39pm
5
Yeah the team have made the decision never to change values reported by an API. That is up to the end user. So it will never be merged.
You have to create your own template sensors:
template:
- sensor:
- name: "Downstairs Filter Left"
icon: "mdi:air-filter"
unit_of_measurement: "hrs"
state: "{{ (states('sensor.robovac_downstairs_filter_left')|float(0)/3600)|round(0) }}"
- name: "Downstairs Main Brush Left"
icon: "mdi:ruler"
state: "{{ (states('sensor.robovac_downstairs_main_brush_left')|float(0)/3600)|round(0) }}"
- name: "Downstairs Sensor Clean Left"
icon: "mdi:contactless-payment"
state: "{{ (states('sensor.robovac_downstairs_sensor_dirty_left')|float(0)/3600)|round(0) }}"
- name: "Downstairs Side Brush Left"
icon: "mdi:weather-hurricane"
state: "{{ (states('sensor.robovac_downstairs_side_brush_left')|float(0)/3600)|round(0) }}"
