I have been using for a long time Xiaomi aqara integration. I’ve set up 3 gateways aqara and bunch of devices (sensors, switches and so on) but after last update i noticed that “Integrations” show exact the same gateways as detected “Xiaomi miio integration”
Should I migrate to new integration or stay at “Xiaomi aqara”. Which solution is better/stable/more functional?
Same here. Did you try it?
Edit: Tried it and while everything was working as before, I lost the xiaomi_aqara.play_ringtone and xiaomi_aqara.stop_ringtone services. So don’t try it.
I have the same question. What is the difference between the two?
I’ve searched around and I found a thread stating that
Xiaomi_Miio uses direct TCP connection to the gateway.
Xiaomi_aqara uses UDP multicast address for communication with the gateway.
also, from the docs, I read that Xiaomi_Miio is [Local Polling]
while the Xiaomi_aqara is [Local Push]
So the Xiaomi_aqara, which should also be the older integration, seems overall better to me.
@jojoro which hub do you use ? Thinking of buying one as I’m not able to get P1 motion sensor to work with Z2M. This is the hub that I’m thinking of
https://www.aliexpress.com/item/1005004751106466.html?spm=a2g0o.productlist.0.0.21671ba8FBp6qu&algo_pvid=bb42dc5f-d0dd-401c-8dd4-92d242e2aacf&algo_exp_id=bb42dc5f-d0dd-401c-8dd4-92d242e2aacf-1&pdp_ext_f=%7B%22sku_id%22%3A%2212000030338529339%22%7D&pdp_npi=2%40dis%21USD%2139.62%2130.9%21%21%21%21%21%402101e9d316684417987844382e4425%2112000030338529339%21sea&curPageLogUid=lXnqFoQHBZXS
Posted this same question here
Xiaomi MIIO vs Xiaomi Aqara integration · Issue #83464 · home-assistant/core (github.com)
HA V: 2023.3 here.
Xiaomi_miio not connected to the cloud.
In my scenario I can see some differences between the two:
Xiaomi_aqara detects more sensors: like a wall switch, magnet sensor, motion sensor. Those are missing in Xiaomi_miio.
Xiaomi_miio exposes some attributes of some sensors that Xiaomi_aqara does not and viceversa. Example in Xiaomi_miio I can see the Power consumption of the Power Plug sensors.
Example in Xiaomi_aquara I can see the Battery Level of a Weather sensor.
Is there any way to force a missing sensors detection for Xiaomi_miio?
Why some sensor’s attributes are not exposed?
I would love some guidance on this. Thanks
