Hi, all
I have few Quingpin CGDK2 sensors. I successfully got the bind key for all of them, but one. I have used the Telink Flasher to get the key. One sensor behaves in a weird way. I can connect to it and pair with it. Once connected I press on Do Activation and receive 17:54:18: Activating now, please wait…
Bind key does not appear. Nothing happens. I have even left if in that state overnight and it just drained the battery.
I have tried factory-resetting it numerous times.
Does anyone have any ides as to what can be done?
Connect, select “Do activation” The log will say Activating now, please wait
Hold the button at the rear of the device until the Bluetooth symbol flashes. The device will disconnect.
Reconnect, select “Do activation” then momentarily press the button.
The Device Id, MI Token and Binding key values will be retrieved.
