Hi!
I have that sensor and tried it with conbee 2. The Phoscon GW app does not recognize it, but the old Deconz zigbee network application see it. The “last seen” and some data changes when light-level changes.
It is an already opened ticket on Dresden elektronik´s Git repository here:
Nice Thank you Bollux!
I also have a CC2531 and a programmer on the way from China, that could be flashed with zigbee2mqtt firmware or used as a sniffer/packet analyzer.
i am gonna try the addon in HA, since i think it could be useful for more devices.
Now that light sensor is working with conbee ll / Deconz after upgrade to Deconz 5.3 Does not show up in Phoscon app, but in the old app where you see the mesh, and as lumi.sen_ill.mgl01 (sensor.lightlevel_xx) in HA.
So just to confirm I have just fired up one of these devices and using zigbee2mqtt with my Texas Instruments Z-Stack ZNP CC2531 as co-ordinator it does indeed work.
Just pressed the pair button on the sensor and off we went. Didnt need to use any apps to get it joined to zigbee2mqtt.
Note that for cheap shipping they remove the battery so you will need to get a CR2450 battery locally.
