Xiaomi Mijia Smart Multi-Function Gateway (DGNWG04LM) support
I have a DGNWG04LM SG getaway.
Product model:DGNWG04LM v2 sg version
internal model:lumi.gateway.mihk01
The first thing you want to do is download the Mi Home App from Android and iOS stores and then connect the gateway to your WiFi router. Note that some mijia hub only WiFi 4 on 2.4Ghz is supported, so it’s important that your router supports the 2.4GHz band, otherwise it won’t connect.
Region test
hk server ok
sg server ok
tw server ok
china server failure
German server failure
I Can’t get the key to add the second gateway in ha
