Dear AlexxIT!
Wondering what your future plans are for integration? What developments are expected?
You could write a little summary about future plans - if you think
I am currently using the Xiaomi ZNDMWG03LM gateway with your integration and the Zigbee2MQTT component with a CC2531 dongle in parallel.
I assigned some of my zigbee devices to one, the rest to the other system. Both system working very well, parallel. (although the CC2531 had to be soldered to an antenna for better reception)
My big dilemma is which system to use. I like the Xiaomi Gateway because it runs in parallel with MI Home, so I also have a cloud-based option that I think is supercool.
Zigbee2MQTT, on the other hand, is more widely used, appears to be more common, but the CC2531 has limitations (handling a limited number of devices, semi-finished, not fully stable ZigBee 3.0 support, etc.).
What do you think, AlexxIT, is it possible that one day, somehow Your solution will be part of the Zigbee2MQTT package? Or the two solutions will be connected some other way? And what about the ZHA component? (I haven’t even tried this …)
For example, the Zigbee2MQTT project has a repeater firmware for the CC2531. Is there a way to possibly use this in your integration? (it would be good because then I could use my two CC2531 dongles to extend signal coverage of the ZNDMWG03LM
So I’m interested about what are the future plans with the integration? What improvements are You working on?
And thanks for Your efforts so far!
EDIT: Is there a way to use the beep function of the ZNDMWG03LM? It beeps only during pairing, or if I press the buttons on connected devices. It has some kind of Guard function (not tested yet), which can give alarm tones, and can be enabled from Xiaomi Home app…
