Xiaomi Mijia Smart Multi-Mode Gateway (ZNDMWG03LM) support
@Blade001
I couldn’t agree more!
You are right guys. :grinning:
Because my frustration level was so high I´m decided to order the new yeelight mesh gateway.
So my hope was that I can implement it with home kit and it worked perfectly. This Gateway was automatically discovered by the HomeKit-Controller integration as well as all attached yeelight mesh lights.
Hi, i have the Gateway 3 with firmware 1.45_0012 and my problem similar this. The Gateway no responde. Have you sucess? @AlexxIT how I resolve to be able to integrate with h.a?
Dear @AlexxIT!
I’ve a question about the devices’ reported values.
I have a LLKZMK11LM (Xiaomi 2 channel relay). It reports the state of the 2 switches, consumption (W) (I have nothing connected to it, but it shows 0. The relay module self consumption is between 1-2 W) and used energy summary (kWh) - this is shown correctly I think.
My question is: how can I view the link quality, voltage, and temperature of the unit? If I pair it with zigbee2mqtt, these values are shown…
Is it a limitation of the ZNDMWG03LM? - Maybe the MQTT server in it swallow these values? Or is it possible to modify / improve Your code, to extract these informations too?
ps: Te link quality seems not shown for any devices…
Regards, F
You can see LQ in debug logs of component. Not all users want unnecessary sensors. I need develop some settings. It’s need time.
Try reboot gw. I think in some cases gw block any connection to it.
Well, these are really not so important values, I agree.
Try to ping it, and try to login with Telnet, to see if its operating normally…
you can also try mqtt-explorer. With this tool, you can connect to your MQTT servers, and you can monitor communication, that may help solve things…
Hello all,
I am looking for a solution to receive a notification when any sensor is unavailable/offline (battery problem, disconnection,…).
In the documentation, I noticed :
**Ignore offline** device status.
# /config/customize.yaml switch.0x158d0003456789_switch: ignore_offline: 1 # any non-empty value
So, I wondered if there was a solution with this integration to detect status of the sensor (unavailable/offline) ? Do you have any idea ?
If not, how do you do it ? The idea is to be informed when any sensor is unavailable/offline
Currently, I use :
  • Xiaomi Button (WXKG01LM)
  • Xiaomi Door Sensor (MCCGQ01LM)
  • Aqara TH Sensor (WSDCGQ11LM)
  • Aqara Motion Sensor (RTCGQ11LM)
Thanks for your help !
any luck with version 1.4.7_0065 ?
Only just found this thread and my gateway is fully updated :sob:
I have moved all zigbee devices to a CC2531 for fun but have four BLE temp sensors that I would like to access without going via nodered to alexa and back to hass!!!
I have model ZNDMWG03LM with firmware 1.4.6_0030, on the previous version
of Gateway integration, all thing are OK. The ZNDMWG03LM are detected 4 Plant monitor and Xiaomi smart lock N100.
With v0.11b8, the Gateway can be detected and have a token:
But when submit, the error appear:
How to fix it, Do I must to downgrade the firmware to before 1.4.6_0030?
Thanks for any advise !!!
Dzung Hoang
I’ve updated 1.4.6_0012 to the custom fw ( https://github.com/serrj-sv/lumi.gateway.mgl03/tree/main/firmware ) with Telnet but no ble firmware is updated I suppose. I still have /data/firmware/full.gbl file present. How to update? I did few reboots already.
Is the v1.4.7_0115 enough stable to give him a try? Sometimes I have zigbee presence detector that disconnects so maybe it’s improved in 1.4.7.
Last question is it possible do downgrade from the custom 1.4.7 to custom 1.4.6 using easy telnet method?
On the screenshot we see tha you are using v1.4.6_0043 . This one is not supported
No that is alert. My firmware version as:
My bad. I think the support of 1.4.6_0030 was removed. Try to downgrade to the recommended 1.4.6_0012 custom firmware with Telnet…
Hi Gents,
I successfully integrated the ZNDMWG03LM (1.4.6_0012) to Home Assistant 2020.12.2.
I can see all zigbee devices but not my BLE “Mi Temperature and Humidity Monitor”.
In Mi Home, I see them through Bluetooth Mesh gateway (thus have also graphs).
Do you guys succeeded in integrating these BLE devices in HA & AlexIT, please?
PS: After enabling debug miio, I can see this traces like this each 5 sec.:
2021-01-06 15:32:45 DEBUG gateway3 192.168.1.104 | [MI] b’[20210106 16:32:44] [D] ot_agent_recv_handler_one(): fd:18, msg:{“method”:"_async.ble_event",“params”:{“dev”:{“did”:“blt.3.13eqbnmak5s00”,“mac”:“58:2D:34:3A:E8:1C”,“pdid”:426},“evt”:[{“eid”:4102,“edata”:“ed01”}],“frmCnt”:252,“gwts”:1609947164},“id”:196} length:189 bytes’
2021-01-06 15:32:45 DEBUG gateway3 192.168.1.104 | Process BLE {‘dev’: {‘did’: ‘blt.3.13eqbnmak5s00’, ‘mac’: ‘58:2D:34:3A:E8:1C’, ‘pdid’: 426}, ‘evt’: [{‘eid’: 4102, ‘edata’: ‘ed01’}], ‘frmCnt’: 252, ‘gwts’: 1609947164}
But I don’t see any device. How could I integrate this TH sensor, please?
Best regards
Fred
Never mind,
I reply to my own question:
After having rebooted the gateway and after some time, I remarqued that the BLE device is showing now and have all indicators too.
Many thanks
Fred
I’ve downgraded to mod fw 1.4.6_0012 and can be telnet to gateway as follow:
But the same error " Can’t connect to gateway" when submit using IP of gateway. I should be reset the gw to the default factory or not. In that case, what about the token key?
I reset gw, reconfigure it from Mi Home app, have new token, but the same result. And Gateway3 log show:
2021-01-14 06:06:32  DEBUG    xiaomi_cloud  MiCloud step1
2021-01-14 06:06:32  DEBUG    xiaomi_cloud  MiCloud step2
2021-01-14 06:06:32  DEBUG    xiaomi_cloud  MiCloud step3
2021-01-14 06:06:33  DEBUG    main          Loaded from MiCloud 6 devices
