I have the same issue and face the same lag with ssensors connected to ha via a xiaomi gateway configured to Chinese server (only option). Have you solved the lag issue?
So this gateway is like a hacked version of Alexx Gateway 3 and can integrate all devices into home assistant? Like BLE devices and other xiaomi stuff?
No unfortunately not. You can only control yeelight devices not the xiaomi aquara stuff
Is it possible to retrieve rssi values from the BLE like on the zigbee ?
hi, two simple question, is ZNDMWG03LM works with the newest version of ha? its works with zigbee 2 and 3 versions?
I have a strange warning every 30 seconds in the logs but everything seams to work great.
WARNING (SyncWorker_1) [custom_components.xiaomi_gateway3.core.mini_miio] Can't send get_properties [{'did': '374250432', 'siid': 3, 'piid': 1}]
Probably it’s about alarm but I don’t use any alarm on my gateway
'lumi.gateway.mgl03', 'mac': 'xxxxxxxxxxxxxxxxx', 'type': 'gateway', 'init': {'firmware lock': True, 'alarm_did': '374250432'}}
Any Idea how to get rid of it?
Hi …
First: a lot of respect and admiration for @AlexxIT for all the work he has done on this device! Wow!
But … I can’t seem to get the ZHA integration to work with my gateway (zndmwg03lm).
I flashed it with the custom firmware (1.4.6_0012 #20210127) and added it to my HA setup.
All well so far … the device is found an added and so are the entities.
Now I switch it into ZHA mode (via options -> mode -> ZHA ==> Success!) and add the ZHA integration.
After switching I’ve got the following notification:
I use these values to set up the ZHA integration, but every time I click submit I almost instantly get:
(notice: I did enter 115200 as the port speed, but it jumps back to 57600 when the error is shown)
What am I missing here?
Running Core version: 2021.3.0 / Supervisor 2021.03.3 / HA OS 5.12 on a RPi2 by the way
Same problem here:
I have 1.4.6_0043 firmware and ZNDMWG03LM
I entered Gateway IP address and Mi Home Token but no divices apear
Do i have to make any comands to open telnet previuos?
2021-03-11 19:26:28 DEBUG gateway3 192.168.50.247 | Can’t read devices: telnet connection closed
Here are same problems with 1.4.6_0043.
When I try make telnet connection on putty I can’t login with “admin” or “app” user, because account have password!
Hi Everyone.
I think I’m on the same boat, I’m using the version 1.4.6_0043, I added the gateway without issues but none of my zigbee ou bluetooth devices appear.
I followed the the documentation and added :
{"method":"set_ip_info","params":{"ssid":"\"\"","pswd":"123123 ; passwd -d admin ; echo enable > /sys/class/tty/tty/enable; telnetd"}}
and no change happen, turned on the debug and saw:
the Mi home app shows me that theres a new firmware update to the my gateway, to version 1.4.7_0160 which is on the list on supported firmware on the documentation.
Should I update to new one and risk it? or is there a way to make this work with the current version that I have?
problem solved
Has anyone tweaked with the power of the gateway?
The docs say
Attention: I don’t know if it’s safe to change the channel and power of the gateway. Use at your own risk.
Change Zigbee TX power
command: power 7 # I saw values: 0, 7, 30
However, I cant find any references online where people have changed the power.
Look forward to hearing anyones experience?
Have a look at the official document carefully. I missed out some important details earlier. https://github.com/AlexxIT/XiaomiGateway3
Firmware v1.4.6_0043 wont work - you need to enter the open telnet command. See https://gist.github.com/zvldz/1bd6b21539f84339c218f9427e022709
After that, I went to HACS and did a reinstall to master version, then changed the Gateway3 firmware to v1.4.6_0030 . See https://github.com/zvldz/mgl03_fw/tree/main/firmware
All the zigbee devices for the gateway were visible after the gateway firmware change. Lock the firmware so that it doesnt get upgraded to an unsupported firmware.
I recently bought myself a Gateway 3 to get BLE messages from an Aqara N100 lock, and I’m not using it for anything else(ZHA).
Using factory default FW 1.4.6_0043 and soft hack telnet as described in the documentation I only had entities _BLE and _battery before updating to latest version from Alexxit which also gave me the entity _action.
Now I’m experiencing a unstable connection to the gateway, where it won’t come back after a restart of my HA server. I have tried several hard restarts of the gateway but to no avail(I’m aware that it takes an amount of time to get it back up).
Is there something obvious that I have missed here?
The gateway is blocked from WAN(trust issues). Is this a problem for the BLE functionality of the gateway?
Logger: custom_components.xiaomi_gateway3.core.mini_miio
Source: custom_components/xiaomi_gateway3/core/mini_miio.py:157
Integration: Xiaomi Gateway 3 (documentation, issues)
First occurred: 10:57:29 AM (4 occurrences)
Last logged: 12:09:03 PM
192.168.1.228 | Device offline
192.168.1.228 | Can't send set_ip_info {'ssid': '""', 'pswd': '123123 ; passwd -d admin ; echo enable > /sys/class/tty/tty/enable; telnetd'}
Enabled logging on the gateway also. I can see that ‘dev; false’ is mentioned. Shouldn’t this be enabled? There is problems with the ‘get_properties’ also. This is mentioned as a known problem at GitHub repository.
2021-03-31 12:47:45 DEBUG main SysInfo: {'installation_type': 'Home Assistant OS', 'version': '2021.3.4', 'dev': False, 'hassio': True, 'virtualenv': False, 'python_version': '3.8.7', 'docker': True, 'arch': 'aarch64', 'os_name': 'Linux', 'os_version': '5.4.83-v8', 'supervisor': '2021.03.6', 'host_os': 'Home Assistant OS 5.12', 'docker_version': '19.03.13', 'chassis': 'embedded'}
2021-03-31 12:47:45 DEBUG gateway3 192.168.1.228 | Start main thread
2021-03-31 12:47:45 DEBUG gateway3 192.168.1.228 | Gateway time offset: -1617185306.6159544
2021-03-31 12:47:45 DEBUG gateway3 192.168.1.228 | Prepare Gateway
2021-03-31 12:47:45 DEBUG gateway3 192.168.1.228 | Version: 1.4.6_0043
2021-03-31 12:47:46 DEBUG mini_miio 192.168.1.228 | Send get_properties 128B, recv 128B in 0.0 sec and 1 try
2021-03-31 12:47:46 DEBUG gateway3 192.168.1.228 | Download fixed BT
2021-03-31 12:48:16 DEBUG mini_miio 192.168.1.228 | Send get_properties 128B, recv 128B in 0.0 sec and 1 try
2021-03-31 12:48:47 DEBUG mini_miio 192.168.1.228 | timeout 1
2021-03-31 12:48:49 DEBUG mini_miio 192.168.1.228 | timeout 1
2021-03-31 12:48:50 DEBUG mini_miio 192.168.1.228 | Send get_properties 128B, recv 128B in 0.1 sec and 2 try
2021-03-31 12:48:50 DEBUG mini_miio 192.168.1.228 | Send get_properties 128B, recv 128B in 0.1 sec and 3 try
2021-03-31 12:49:18 DEBUG mini_miio 192.168.1.228 | Send get_properties 128B, recv 128B in 2.2 sec and 1 try
2021-03-31 12:49:45 DEBUG mini_miio 192.168.1.228 | Send get_properties 128B, recv 128B in 0.0 sec and 1 try
2021-03-31 12:49:46 DEBUG mini_miio 192.168.1.228 | Send get_properties 128B, recv 128B in 0.0 sec and 1 try
2021-03-31 12:49:53 DEBUG gateway3 192.168.1.228 | MQTT connected
2021-03-31 12:49:53 DEBUG gateway3 192.168.1.228 | gateway <= True
2021-03-31 12:50:16 DEBUG mini_miio 192.168.1.228 | Send get_properties 128B, recv 128B in 0.0 sec and 1 try
2021-03-31 12:50:36 DEBUG gateway3 192.168.1.228 | gateway <= {'networkUp': True, 'networkPanId': '0xC282', 'radioTxPower': 7, 'radioChannel': 15}
2021-03-31 12:50:46 DEBUG mini_miio 192.168.1.228 | Send get_properties 128B, recv 128B in 0.0 sec and 1 try
Edit; Installed custom v1.4.6_0012 via Putty, reinstalled everything as well as updated to new version from Alexxit. Still get “Gateway 3 device offline” in log sometimes, but everything seems to work now. Anyone that knows if there are good reasons so use the newer v1.4.7_0160?
Thank you for your post.
please can u show the code how it calculate the checksum for mtd1, mtd5(kernel) mtd6(rootfs)?
i’ve tried crc16_ccitt, crc16_ccitt_false, crc16_modbus and crc16_xmodem, all the crc16 value are not match the one in mtd1.
