BLE don’t supported yet. Have you read readme?
yep of course, but I can’t even integrate the gateway … shouldn’t it appear as an entity?
When are you planning to add support for BLE?
Yes it should. Do you have a zigbee device? The problem may be that there are no child devices.
Thanks work great (Cube and switch).
Looking foward to BT integration.
i think the same… anyone can confirm?
i will try it soon
thanks a lot
Already add Xiaomi Hub 3 without error. But motion sensor only change OFF to ON , can not change ON to OFF , Try on 02 type : Xiaomi motion sensor and Aqara Sensor
I will fix it in future versions.
Hi, it work by a TH sensor associated!!
thanks a lot
thanks a lot @serrj-sv
i was able to permanently activate telnet and open mosquitto permanently in my network with your instructions.
thanks a lot @AlexxIT
your integration works here with 2x Aquara Door Sensors (MCCGQ11LM), 2x Aquara Motion Sensors (RTCGQ11LM) and 3x Aquara TH Sensors (WSDCGQ11LM) - with exception of the battery status.
same here. (RTCGQ11LM)
Well, I try to short these two TP as a test before I solder a button.
But it’s not working… Weird.
It should be TP5, not TP7. I corrected my post. But you can just switch on/off power instead.
@chrisrock confirmed he managed to recover his device using my instructions
Check updates read me. Don’t fixed it yet.
Thank you Alexx !!!
Now xiaomi stateless buttons work! I added automation to reset the state, repeated presses now work. I think you can add the same automation to reset the motion sensor.
Also now I have the illuminance state of my motion sensor.
Great job!
Already add component by HACS but in GUI: Configuration --> Integrations does’n show " Xiaomi Gateway3" on list. Are there any code must be add to configuration.yaml file, before?
No, you must only reboot home assistant
@serrj-sv
Thanks for the instructions, I finally managed to unbrick my gateway.
And also finds out the reason that bricked my gateway in the first place.
I was trying to run unsquashfs on a lxc container (Proxmox VM), resulting in failed inode creation.
After flashing that rootfs back, it caused mounting failure, eventually a boot-loop.
So for everyone that wants to follow the flashing instructions, make sure your unsquashfs runs without outputting any errors. Otherwise, you might brick your device.
HASS reboot already, but GUI does’n show " Xiaomi Gateway3" on list. Any reason?
PS: I using a custom component from @AlexxIT for a Xiaomi Hub 3 with original firmware.
