It shows as “Xiaomi Gateway 3” in the integration list. That a space between “gateway” and “3”. If you’ve used search, this should help.
any recommend automation for motion to reset ? Pls share me
Hi, I have two old xiaomi gateways with many attached devices that fork just fine with HA.
I would like to use ZNCZ04LM eu sockets with HA through xiaomi/homekit integration.
I do have a multimode gateway paired with the socket, its set to an european server (the ZNCZ04LM does pair only with european server, unfortunately no chinese), HA detects the multimode gateway as a homekit device, pairing is successful, but HA only shows one device, the gateway itself, no socket.
What can be the problem?
Not all devices shared with HomeKit
Added support some BLE devices. You need reboot Gateway.
Hi AlexxIT, thanks for your answer.
Does your integration support ZNCZ04LM zigbee socket?
I am now using it through cc2531, but I’m more used to xiaomi devices and also I have a lot of ble thermomethers to use with the gateway.
@AlexxIT
Thanks for adding BLE support, I was running previous version (so I followed your instructions to reboot my gateway).
I have the exact setup you tested, i.e. Gateway v3 with 3 of the temperature sensors (LYWSDCGQ/01ZM) but am unable to see any of these devices in Home Assistant !
Have also tried removing the integration and the repo entirely and rebooting HA each time, no luck as of yet.
@AlexxIT
Hello! Thanks for plugin! I installed it but in log (at debug level) I have many rows with next text:
2020-09-07 15:25:16 DEBUG (Thread-8) [custom_components.xiaomi_gateway3.gateway3] 192.168.0.103 | Read devices
about 10 rows in second. And I not have any discovered devices. Do you have any ideas about it?
I have the same issue
Thanks. Discover my 4 BLE device (LYWSD03MMC). Nevertheless it seems to skip some value as i have only on measure for 4 hours. In mihome i have a measere each hours. Any idea? Log needed.
Please tell me if can help
it’s not zigbee3, but it’s supported. aqara eu plug is zigbee3 (not supported by mgl03 firmware). you can also integrate mesh devices (yeelight). they use miot spec way of talking to the hub.
well it’s registered to cloud using regular way like the old sensors. aqara eu plug or light sensor are connected using zigbee3 auth methods (zigbee3_get_install_code, zigbee3_get_auth_random, zigbee3_bind).
@rezmus In the latest release, I added a display of the Zigbee version according to the hub database.
Opple displays as 1.2, although they are exactly on ZB3. Only light sensor displays as 3.0.
i guess the most important thing is that mmeu01 plug works fine with this hub, while maeu01 does not. it used to work with older firmwares, i could control it via miio cmd, but with latest firmwares it pairs and responds with error to any miio cmd. it also does not also send props to the hub.
