Yep.
These are available on the resources.
And there are no errors reported when I edit the Lovelace.
What else could I miss?
My card
- copy to card manual
- modify line 11,55,99
type: vertical-stack
cards:
- type: vertical-stack
cards:
- type: markdown
content: '#### 5 Ghz'
- type: 'custom:auto-entities'
filter:
include:
- attributes:
router_mac: 'XX:XX:XX:XX:XX:XX'
connection: 5 Ghz
card:
type: 'custom:flex-table-card'
clickable: false
sort_by: ip+
columns:
- data: icon
modify: '"<ha-icon id=\"icon\" icon=\"" + x + "\"></ha-icon>"'
- data: friendly_name
- data: ip
modify: 'x === "0:0:0:0" ? "" : x'
- data: mac
- data: signal
modify: 'x === 0 ? "" : x'
- data: state
modify: 'x === "home" ? "online" : "offline"'
- data: online
modify: 'x === "0:00:00" ? "" : x'
- data: last_activity
modify: 'x.replace(/T/i, " ")'
css:
table+: 'padding-top: 15px;'
'tbody tr:nth-child(even)': 'background-color: #a2542f6;'
td.left: 'padding: 10px 10px 10px 10px'
th.left: 'padding: 0px 0px 10px 10px; width: 200px'
'th.left:nth-child(1)': 'width: 44px'
'th.left:nth-child(2)': 'width: 330px'
cards:
- type: markdown
content: '#### 2.4 Ghz'
filter:
include:
- attributes:
connection: 2.4 Ghz
card:
clickable: false
sort_by: ip+
columns:
- data: icon
- data: ip
- data: mac
- data: signal
- data: state
- data: online
css:
cards:
- type: markdown
content: '#### Lan'
filter:
include:
- attributes:
connection: Lan
card:
clickable: false
sort_by: ip+
columns:
- data: icon
- data: ip
- data: mac
- data: signal
- data: state
- data: online
css:
Do you have connected devices in the integration? In what mode does the router work?
@dckiller51 , this is exactly the card I have used (as the GIT), with one exception, removed line 1.
@dmamontov , I have set the MAC of the main router.
My setup is AX6000 as the main unit set as the main DHCP unit, and another AX1800 set as a MESH unit connected with a cable (not wifi).
I do have devices detected in the integration:
Any additional ideas :)?
Thanks for your support.
Try to look in the development panel for one of the connected devices “device_tracker.xxx”. What parameters will it have?
@dmamontov, got it to work.
Thank you very much for your help.
It seems like I had to change the MAC address of the connected router.
It seems like the MAC address is different in the mihome application (maybe of the mesh unit?).
Thank you very much for your support.
Hi! I successfully added my AX3600 and AX6000. AX9000, instead, is not working.
They are all connected in mesh mode, AX9000 is the parent.
Thanks!
I made this card, if anyone is interested, this is the code:
type: custom:config-template-card
variables:
- states['sensor.speedtest_download'].state
- states['sensor.speedtest_upload'].state
- states['sensor.speedtest_ping'].state
entities:
- sensor.speedtest_download
- sensor.speedtest_upload
- sensor.speedtest_ping
card:
type: entities
show_header_toggle: 'off'
style: |
.card-header {
padding: 0px 0px 0px 0px !important;
entities:
- type: custom:hui-vertical-stack-card
cards:
- type: horizontal-stack
cards:
- type: picture
style: |
ha-card {
--paper-card-background-color: 'rgba(0, 0, 0, 0.0)';
--ha-card-background: "rgba(0, 0, 0, 0.0)";
--ha-card-box-shadow: 'none';
image: /local/images/ax1800.png
- type: custom:button-card
layout: icon_name_state2nd
show_icon: true
show_state: true
styles:
grid:
- grid-template-columns: 50px auto
icon:
- padding: 0px 0px
- height: 30px
- width: 30px
card:
- '--ha-card-background': rgba(0, 0, 0, 0.0)
- '--ha-card-box-shadow': none
state:
- padding: 0px 10px
- justify-self: start
- font-family: Roboto, sans-serif
- font-size: 15px
name:
- padding: 0px 10px
- color: var(--secondary-text-color)
name: Tempo de atividade
entity: sensor.ax1800_uptime
icon: hass:router-wireless
- type: custom:mini-graph-card
height: 20
line_width: 2
font_size: 70
hours_to_show: 168
points_per_hour: 1
show:
extrema: true
fill: true
style: |
ha-card {
border-radius: 5px;
entities:
- sensor.ax1800_devices_2_4ghz
icon: hass:router-network
color_thresholds:
- value: 90
color: '#3498db'
- value: 120
color: '#f39c12'
- value: 150
color: '#E45E65'
height: 20
line_width: 2
font_size: 70
hours_to_show: 168
points_per_hour: 1
show:
extrema: true
fill: true
style: |
ha-card {
border-radius: 5px;
entities:
- sensor.ax1800_devices_5ghz
color_thresholds:
- value: 90
color: '#3498db'
- value: 120
color: '#f39c12'
- value: 150
color: '#E45E65'
height: 20
line_width: 2
font_size: 70
hours_to_show: 168
points_per_hour: 1
show:
extrema: true
fill: true
style: |
ha-card {
border-radius: 5px;
entities:
- sensor.ax1800_memory_usage
icon: hass:memory
color_thresholds:
- value: 20
color: '#00ff00'
- value: 40
color: '#f39c12'
- value: 50
color: '#E45E65'
height: 20
line_width: 2
font_size: 70
hours_to_show: 168
points_per_hour: 1
show:
extrema: true
fill: true
style: |
ha-card {
border-radius: 5px;
entities:
icon: hass:download
color_thresholds:
- value: 100
color: '#E45E65'
- value: 150
color: '#f39c12'
- value: 300
color: '#00ff00'
height: 20
line_width: 2
font_size: 70
hours_to_show: 168
points_per_hour: 1
show:
extrema: true
fill: true
style: |
ha-card {
border-radius: 5px;
entities:
icon: hass:upload
color_thresholds:
- value: 50
color: '#E45E65'
- value: 90
color: '#f39c12'
- value: 100
color: '#00ff00'
height: 20
line_width: 2
font_size: 70
hours_to_show: 168
points_per_hour: 1
show:
extrema: true
fill: true
style: |
ha-card {
border-radius: 5px;
entities:
icon: hass:connection
color_thresholds:
- value: 10
color: '#00ff00'
- value: 20
color: '#f39c12'
- value: 40
color: '#E45E65'
- type: grid
cards:
- type: button
tap_action:
action: toggle
entity: switch.ax1800_reboot
- type: button
tap_action:
action: toggle
entity: light.ax1800_led
show_state: true
columns: 2
Hi guys,
i tried to install it via HACS and configured through the Integration GUI, i put the ip and the password used to login in the admin console of the router, after that it says that the configuration is ok but in the HA Core Logs i’ve found
2021-07-28 11:16:07 WARNING (MainThread) [homeassistant.config_entries] Config entry '192.168.0.1' for miwifi integration not ready yet: None; Retrying in background
and in the integration page the integration is circled in red and says retry configuration: none
any suggestions?
Hi everyone,
I’m trying to add Xiaomi Mi Wi-Fi Range Extender Pro V3 R03 ( Model: xiaomi.repeater.v3 ).
device_tracker:
- platform: xiaomi_miio
host: 192.168.8.104
token: TOKEN_FROM_TOKEN_GRABBER
but I’m getting this error.
Error setting up platform legacy xiaomi_miio
3:56:18 AM – (ERROR) Device tracker
Device unavailable or token incorrect: Unable to discover the device 192.168.8.104
3:56:17 AM – (ERROR) Xiaomi Miio
error while reading discover results: Error in path (parsing) -> header parsing expected 8497 but parsed 0
3:56:17 AM – (WARNING) /usr/local/lib/python3.9/site-packages/miio/miioprotocol.py
I know this supports Xioami Mi Wifi Repeater V2 but is it possible to add support to latest Mi Wi-Fi Range Extender Pro?
This is a slightly different integration and it does not support repeaters. You are trying to use the standard one. I think this is in another topic.
Hi Dmitriy
thank you a lot for your effort!
I have a few question here, maybe only clarifications. I have one AX6000 and one R3P device, however, the AX6000 works as AP and R3P as repeater since I am using opnsense as the main router. The integration finds both devices, return their status, led, etc… however, no devices connected. Enabling the force mode, the AX6000 shows devices on Wifi but none at LAN, the same for the R3P.
From the Q&A it looks like that while in force mode the IP address,etc… is not available, however, any idea why the integration do not shows any devices with force mode off? Maybe I have just misread something, just want to make sure everything is set correctly.
thx, tomas
I have unusual problem. I have two xiaomi routers working in a mesh mode. They are both supported by this integration. I set up lovelace card from to monitor my devices from here miwifi perfomance table · GitHub
But all my devices have same the ip 127.0.0.1. Maybe I messed up something with my home assistant or my router. I’m not sure.
Can someone help me with this?
Corrected, update to Release v1.2.6 - 2021-11-05 · dmamontov/hass-miwifi · GitHub
Great, tnx. It’s working again.
I have problem with tracking devices. All devices that are connected to my miwifi router are offline and tracker say that devices are away.
I can’t figure this out. I removed miwifi integration and add it again. When I add again miwifi integration all devices are online and home, but after a while all devices are offline and away.
I use for a long time this configuration.yaml entry with no issues
device_tracker:
- platform: xiaomi
host: X.X.X.X.
password: xxxxxxx
Home assistant is upgraded to last updates.
and what do you have in the logs when it disappears? and what router? standard integration must be disabled, they conflict, as stated in the repository.
I have Xiaomi AX1800 working in mesh mode with another xiaomi router. They are routers for my local lan. AX1800 is a gateway to cisco rv320 router which is than gateway to two lte routers. I use cisco for load balancing because i have poor internet connection.
I commented out device tracker restareted ha but no luck.
This is what i have in logs:
“AttributeError: ‘DeviceRegistry’ object has no attribute ‘_async_update_device’
2022-02-06 19:20:19 ERROR (MainThread) [homeassistant.helpers.entity] Update for device_tracker.esp_5c2b27 fails
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 512, in async_update_ha_state
await self.async_device_update()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 716, in async_device_update
raise exc
File “/config/custom_components/miwifi/device_tracker.py”, line 288, in async_update
await self._update_device(self._config_entry, entry)
File “/config/custom_components/miwifi/device_tracker.py”, line 308, in _update_device
device_registry._async_update_device(
2022-02-06 19:20:19 ERROR (MainThread) [homeassistant.helpers.entity] Update for device_tracker.esp_5bf31e fails
raise exc
2022-02-06 19:20:19 ERROR (MainThread) [homeassistant.helpers.entity] Update for device_tracker.julia fails
raise exc
2022-02-06 19:20:19 ERROR (MainThread) [homeassistant.helpers.entity] Update for device_tracker.daniel_a72 fails
raise exc
2022-02-06 19:20:19 ERROR (MainThread) [homeassistant.helpers.entity] Update for device_tracker.galaxy_s21_5g fails
raise exc
2022-02-06 19:20:19 ERROR (MainThread) [homeassistant.helpers.entity] Update for device_tracker.f0_e4_a2_45_52_30_2 fails
raise exc
2022-02-06 19:20:19 ERROR (MainThread) [homeassistant.helpers.entity] Update for device_tracker.esp_15cfdf fails
raise exc
2022-02-06 19:20:19 ERROR (MainThread) [homeassistant.helpers.entity] Update for device_tracker.esp_578786 fails
raise exc
2022-02-06 19:20:19 ERROR (MainThread) [homeassistant.helpers.entity] Update for device_tracker.esp_578787 fails
raise exc
AttributeError: ‘DeviceRegistry’ object has no attribute ‘_async_update_device’”
Thanks, from the logs I see that the logic has changed to hass, I’ll fix it, stay tuned.
Thank you.
